Home > Puma (Tdci) > Prop Shaft UJ grease nipples difficult to access
clifflandy
United Kingdom 2007 Defender 90 Puma 2.4 HT Zambezi Silver
I have tried to grease the UJ's on my 2007 90 TDCi prop shaft but due to the short length grease nipples cannot get my grease gun to 'lock-on'. Should I replace the nipples for a longer version (if so what size?) or is there a slim grease gun or attachment available?
Post #433040 23rd Jun 2015 2:30pm
K9F
Had to grind my standard adaptor off to get it to fit. Top tip from 'Noworries4x4' is to grind two flats instead of all the way round. This will ensure the adaptor will not disintegrate after time.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #433043 23rd Jun 2015 3:06pm
Alternatively unbolt the propshaft so that you can articulate the joints and do the job properly!
Post #433046 23rd Jun 2015 3:25pm
Retroanaconda
Ground the end of my grease gun down on two sides, now it fits nicely between the yokes of the props.
Post #433104 23rd Jun 2015 7:46pm
landy andy
Buy a decent prop shaft. That's what I did.
Post #433127 23rd Jun 2015 8:34pm
K9F
^^^ Rolling with laughter
Good for you! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #433133 23rd Jun 2015 9:00pm
munch90
Post #433140 23rd Jun 2015 9:20pm
Lorryman100
Andy, what prop did you fit? I am curious as I am about to order a front and rear from Gwyn Lewis.
http://www.gwynlewis4x4.co.uk/product/puma...rop-shaft/
http://www.gwynlewis4x4.co.uk/product/puma...l-ext-665/
Post #433141 23rd Jun 2015 9:22pm
munch90
Use a rubber extension tube on the grease gun so you can grease the uj nipple in diffirent postion so the yoke is openned up
Post #433150 23rd Jun 2015 9:34pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
i use a rubber flexible tube on mine, and grease from above when its pointing at 12 o clock. 1953 80"
1987 mini city e
2011 90"
Post #433151 23rd Jun 2015 9:34pm
Happyoldgit
+1 Steve.
http://forums.lr4x4.com
Post #433170 23rd Jun 2015 10:18pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I've tried to grease the nipples (????) while the shaft (??????) was still on the car... Far better, and easier to take the props off, and do it on the bench... Plus it's easier to clean the gunk off.... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #433185 23rd Jun 2015 11:21pm
landy andy
I brought a pair of bailey Morris extreme props, direct from bailey Morris. About £500 for the pair, with a pair of spare UJ's. Very nice quality all made for me and took 3 days. Neither of my original props had grease nipples on the slider section, the rear prop had tiny UJ's that were very difficult to access, and the front UJ's had the grease nipple in the Center of the UJ not between the pivots, so was a remove to grease job, and complete ball ache. Very happy now, and like the idea of same UJ on all joints.
So if anybody wants original props let me know.
Andy
Post #433232 24th Jun 2015 8:11am
JWL
To be honest I've never really had much of a problem greasing the props on any of the Land Rovers I've owned or worked on, yes I can see that people do have problems but by jacking a wheel up so you can turn the prop and by using a grease gun with a flexible tube. By having the nipple access at the top at the transfer box end and at the bottom at the axle end you have opened the yoke so the end of the grease gun can get in. I don't use any fancy grease gun, just the one I've had for years with a good quality end, I'm sure that the sprung "jaws" are split into four.
A lot of the problems with grease guns not latching on properly are due to grit or foreign objects in the end stopping the end from snapping on fully.
Post #433240 24th Jun 2015 8:49am
landy andy
I never had any problem till I had the tdci. They are worse than any others I've greased.
Post #433372 24th Jun 2015 4:53pm
