Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
I was taken to the landrover show in Malvern for Father's Day, spent loads on the kids and treated my other baby to a nice set of black boost alloys brand new for £250 for the five on a show offer that was to good to miss.
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Drained and refilled both axles with fresh oil and once i have sorted the H/Brake shoes and oil seal out i will refill the trannybox aswell
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
changed the engine oil and filter, fuel and air filter, all good an no leaks. DEFENDER 90 TDCI XS,
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Took the caravan to Beith for a service before the summer holidays. It's the first time I have tried the motor with a decent load on it (apart from lugging the wife's purse around 👍) and I was very happy with it. It towed very well, nice and stable with a wee bit of pitching which you'd expect from a SWB motor.
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1872 ![]() ![]() ![]() |
Took the Sankey down a mates to be painted
[URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 ![]() ![]() |
![]() Click image to enlarge Must be trailer day today ..off for a two night camp in Dorset at the weekend so trailer mounted and checked . |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Fitted back on my recently painted headlight surrounds, lots of work to get them so glossy as they had orange peel effect.
Waxed with Meguiar's #26 ![]() Click image to enlarge |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 597 ![]() ![]() ![]() |
Ordered Blindos. Rock and roll.
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Fitted new head unit and mic for Bluetooth.
Another one of those testing moments of Land Rover ownership this morning
![]() Not a lot of evidence of the dreaded diesel bug on the primary gauze on the bottom of the pump but by sloshing the pump up and down in the tank it must have disloged whatever the problem was inside the pump. It would have probably only taken 20 minutes with emptying the "carefully selected objects" in the rear that were in the way but as per usual a Land Rover in distress usually brings out other owners to have a chat, probably in sympathy. All done and dusted and gave it a bit of a workout on the way home and all is good again. There's never any rhyme or reason to when I get caught with this, it can do it with a full tank, an allmost empty one and like today a half full tank. One of these days I will have to thoroughly empty and clean the tank, another one of those things on the "todoit" list |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
Did the tank last weekend, it took about 3hours to remove the towbar bolts and drop/clean it. It was really clogged with bug so worth doing. I snapped a fuel connector and then had to spend a small fortune on a new fuel lone
![]() Today I fitted the nanocom in between bouts of dehli belly ![]() |
Made an internal rod rack for carrying loose sea rods ( not in a case or bag ) for when going sea fishing
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Did my first bit of work on my first LR, replaced all the door bolts with stainless steel ones
