Home > Maintenance & Modifications > Nas style rear step for Defender 90 help.
Mrpheasant
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Sumatra Black
Just wondering if anyone who has got a rear step like this one could help me...
the kit only came with 1 what i would call a support beam, that goes from the step to the defender...
my question is should there be 2? one either side of the step, i took 2 off the towing kit which was on before so in my mind it makes sense for there to be 2 on this step.
any help would be great...
Post #432902 22nd Jun 2015 9:24pm
munch90
Yes should come with 2 bars
Post #432903 22nd Jun 2015 9:26pm
ickle
should be 2!
Post #432904 22nd Jun 2015 9:26pm
munch90
And give the step a good waxoyling in the corners and underneath Thumbs Up
Post #432905 22nd Jun 2015 9:28pm
Already mentioned twice but indeed needs to be two. Thumbs Up
Post #432906 22nd Jun 2015 9:30pm
Mrpheasant
Awesome, thanks guys Thumbs Up will have to get on the phone tomorrow and get one sent out.
Post #432907 22nd Jun 2015 9:31pm
Mrpheasant
Hammerite stuff any good?
Post #432909 22nd Jun 2015 9:33pm
munch90
Not hammerite paint
finnigans anti rust waxoyl
or there are other makes
just a thin spray anti rust fluid , good soak in the corners , under the rubber , inside if poss
they not coated the best from new
Post #432912 22nd Jun 2015 9:44pm
You can't get it inside too well without drilling holes, would small holes big enough for an internal spray tube compromise structural strength?
Post #432921 22nd Jun 2015 10:15pm
Have a look on Topix for the fitting instructions (assuming it's an OEM kit) - looks like you're a bolt or two short as well.
Post #433006 23rd Jun 2015 11:48am
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
I'd also suggest moving the electrics, so there is no chance of them being pulled off by a stray branch...
Post #433015 23rd Jun 2015 12:37pm
Mrpheasant
Yep it shows it as having two Neutral
Post #433561 25th Jun 2015 11:43am
Mrpheasant
I like the idea of that Thumbs Up
Post #433562 25th Jun 2015 11:44am
X4SKP
Hello Mrpheasant
As has been said Yes...there should be two 'arms' in the kit...
and ... Thumbs Up to the 'protected' towing electrics position.
Good Luck SKIP
Post #433599 25th Jun 2015 1:46pm
Mrpheasant
Dumb question maybe but how did you go about mounting it there Skip? Thumbs Up
Post #434018 27th Jun 2015 2:19pm
