![]() | Home > Puma (Tdci) > caterhams LAST problem! |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Don't anyone dare count their friggin' chickens just yet! As for 'Happy Bunnies' where's my shotgun?
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 21st Jun 2015 6:43pm. Edited 1 time in total |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
hasnt he still got front axle to sort out and finish fitting sub
bet there will be few more bits yet |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
Damn it Mal you're far too good with the search...... Front axle is now more of a precaution with the know issues ie recall on the casing and the 2pin diff on the front so gonna replace it whole. It all makes sense now....pulling off and then it all dieing (probably dropped into lo range and hence sensitivity of pedals changed, the adjusting of the hi/lo linkage probably knocked the hi/lo switch wiring and hence seemed to fix things) All the f'in about and it seems to have been 2 simple things - battery and hi/lo switch. |
Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 21st Jun 2015 8:09pm. Edited 1 time in total |
why would it only do it when you pulled away ? if it went into low range setting , you would of had idle jack happen ? battery terminal would show on starting more than anything when drawing highest amps , not seen you say bad starting ? hmm fixed |
you're absolutely right about the idle jack .... when it's happened in first gear it's been alright for the first few yards then died as changing into 2nd gear so I'm not sure? the only other times I'm aware of is when I've been driving along and then there's what has felt like a loss of power but in hindsight I think it's been a loss of pedal sensitivity (presumably due to the lo range triggering)? it would seem there may still be some questions to answer..... and dare I say it I drove over to see my parents earlier and took my dad for a spin to demonstrate how well things were..... and even he commented on how smooth and quiet it was. then when I left I suggested he listened from the outside as I drove off 'quickly'............ |
oh joy.....the neighbours must love me....LOVE me....
almost 11.30 last night and I had to resort to getting the grinder out to remove 1 of the 8 nuts holding the front prop in place. any how I got it out and it's on 'trial'.......... ......sometimes go through life thinking I'm making problems for myself.......it all started about 4.5 years ago |
whats wrong with front prop
the gearbox was out of it only the other day , surly any problem with prop would/should have been found then ? |
prop is fine .....just fine.
my concern is what's connected to it. surprisingly the slack in the rear seems considerably more obvious now (didn't expect that) - must sort the flanges out asap. also on the plus side (albeit this is from a short trial only this morning), the unpleasant tram-lining when slowing down seems to have gone and the general feel seems much more pleasant? will be putting a few more miles on it yet without the prop but I wouldn't have expected def to feel any different really (tanking it yes but while driving like Miss Daisy wouldn't have thought there would be any obvious difference other than perhaps the gear change being a little different)? |
Time to give Munch a breather. He's the only one listening now. Page 9 of this thread just about sums up the whole scenario. Sell it Wayne I'll chip in for a group buy and we could give it a good send off in the crusher. Treat every day as if it is your last....one day you will be right!! |
why give it a good send off in the crusher , good chance there is nothing wrong with it !!!!
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
...and still it goes on Have you checked the fag lighter for correct operation yet Wayne? Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
It's not funny anymore
.....i need help. I even phoned about a new car this morning and they didn't even bother to call back. |
Give it to someone who knows defenders and let them use it for a week
And see what they say |
