Home > Maintenance & Modifications > Simple pressurised oil filler
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I don't know if this idea has been discussed on here before, but I need to fill the gearbox, transfer box and two diffs with oil, and know from past experience it's a real royal pain in the butt trying to get them filled without spilling oil everywhere!
Here's a couple of photos of the pressurised filler bottle I knocked up today in about 20 mins. It's simply a 1 litre P.E.T fizzy drink bottle, with a couple of Schrader valves, a bit of pipe, a simple hose clamp / stopper and a £1 bike pump from Tescos!
The Schrader valve in the base of the bottle is for attaching the pump to pressurise the bottle, while the one fitted to the cap has had the core removed to let the oil flow.. The pipe clamp lets you control or stop the flow..
It's simple, and cheap.. The valves were £3 from Ebay, the bottle was out of the bin, and the pipe and clamp were just salvaged from the bits pile in the shed.. The only "construction" bit is drilling the two 11mm holes for the valves rubber seals to fit in, followed by a tweak with a spanner to make sure things are tightly sealed..
I'd post full construction details, but the photos can say it better than a few words!!!
To use, close the pipe clamp first.. Fill bottle with the required amount of oil, attach pump, poke the pipe in the filler hole, pump the pump a few times and release the pipe clamp.. Topping up the air from time to time.. It's small enough to get into the nooks under the car, and by having the filler coming from the cap end, the bottle can almost be horizontal and still get a decent flow...
Apologies if this has been done before, but nowt came up in the search!!!
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #431981 18th Jun 2015 8:02pm
pob1968
Awesome well done. I will pinch this idea as and when thank you 110 Hardtop
Post #431982 18th Jun 2015 8:08pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
http://www.amazon.co.uk/Spear-Jackson-Pres...en+sprayer
Here's mine. No fear of explosion, don't have to keep filling it. It wasn't me!
Post #432304 20th Jun 2015 8:56am
excossack
I had considered a garden sprayer but wasnt sure if the pipe work would be too smaller diameter to allow the oil to pass through without a lot of force. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #432306 20th Jun 2015 9:15am
Great idea, well done Thumbs Up
Post #432312 20th Jun 2015 9:35am
ozzy57
It works. The oil may need to be warmed up. It wasn't me!
Post #432331 20th Jun 2015 10:48am
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
I bought one of these. Work great and less than £5
http://www.ebay.co.uk/itm/Oil-Fluid-Suctio...OC:GB:3160
Post #432346 20th Jun 2015 11:41am
K9F
^^ Thumbs Up
If you haven't got the Schraeder valves required lying around the gun is probably cheaper too! The fizz bottle is a great innovative idea though! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #432360 20th Jun 2015 12:41pm
mse
Been using a garden type pressure sprayer (2 of) for years...with the drain plug it makes it all so easy Mike
Post #432543 21st Jun 2015 11:49am
