![]() | Home > Maintenance & Modifications > Simple pressurised oil filler |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 ![]() |
Awesome well done. I will pinch this idea as and when thank you 110 Hardtop
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
http://www.amazon.co.uk/Spear-Jackson-Pres...en+sprayer
Here's mine. No fear of explosion, don't have to keep filling it. It wasn't me! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6026 ![]() ![]() ![]() |
I had considered a garden sprayer but wasnt sure if the pipe work would be too smaller diameter to allow the oil to pass through without a lot of force. 1999 Defender TD5 110
Great idea, well done
It works. The oil may need to be warmed up. It wasn't me! |
consumerize Member Since: 27 May 2014 Location: Berkshire Posts: 121 ![]() ![]() ![]() |
I bought one of these. Work great and less than £5
http://www.ebay.co.uk/itm/Oil-Fluid-Suctio...OC:GB:3160 ![]() Click image to enlarge |
![]() If you haven't got the Schraeder valves required lying around the gun is probably cheaper too! The fizz bottle is a great innovative idea though! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Been using a garden type pressure sprayer (2 of) for years...with the drain plug it makes it all so easy Mike |
