Page 820 of 1391 <123 ... 819820821 ... 138913901391>
Welkman
Went to pick up my fuel pipe from colchester dealership in the audi and got stuck in a defender sandwich on the way back. Lovely TD5 behind and a 14 plate 130 double cab in front. Why dont I have enough cash for a new 130 double cab !
Post #431492 16th Jun 2015 10:22pm
Lorryman100
Nothing!! Puma has been sick the last week and hasn't moved off the drive.
Must be a bit of pre cognitive thingy ma jingy going on as I ordered a couple of Ashcroft ATB diffs 3 weeks ago as an upgrade and after changing the clutch which made the Puma a lot quieter, it allowed me to hear a faint grumbling in the rear. So jacked up the rear end and checked the wheel bearings for movement and noise, finding nothing, out came the stethoscope and I got my missus to turn the rear wheel whilst I had a listen at the final drive and it sounds as if one of the diff bearings is about to let go as the pinion bearing appears tight with no movement or leakage but I will double check this once the final drive comes out. Due to workload I needed to wait until this Friday to get time off and get stuck in, can't wait, 3 free days to get everything done. Mr. Green
Post #431516 16th Jun 2015 11:36pm
Brian - I've just fitted them to my 110. Rears are pretty easy, fronts take a lot longer due to CVs etc but well worth it
I also fitted a wide angle fulcrum (rear axle joint) not because there was a problem but the wide angle ones have grease nipples and the engineer has air tools which makes it 5 minute job
Post #431543 17th Jun 2015 7:04am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Took mine for its mot which it passed without any advisories Mr. Green 2004 TD5 Defender 90 xs station wagon
Post #431738 17th Jun 2015 8:51pm
johnszs
i have a ashcroft atb in the front of my truck, it has been excellant, i cannot speak highly enough of it Thumbs Up 2004 TD5 Defender 90 xs station wagon
Post #431739 17th Jun 2015 8:54pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
Drove from home (500m), over the Splügen Pass (2100m), down into Chiavenna (c 300m) for lunch, back to St. Moritz (1700m) for tea, and over the Julierpass (2200m) home.
Total elevation and number of hairpins - who's counting.
One of the most amazing drives one can do in a day, in Switzerland and Italy. Scenery this time of year, unbelievable. I might do it again next month
Smile Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #431759 17th Jun 2015 9:29pm
Lorryman100
I just got the Ashcroft ATB diffs and bearings pre pressed as I wanted to check and rebuild the final drives as required. It will give me a chance to check for wear on the R & P, bearing etc, and I will replace them if required as well as letting me set the pre-load and backlash to get a better understanding of how the transmission is set up on my Puma. The priority just now is the rear diff as I am waiting on Ashcroft to get ABS CV joints back into stock before doing the front diff, as you say Steve the cv joints need to come out to remove the front drive shafts before I can remove the diff so it made sense to me to replace the cv joints and drive shafts at the same time. As I am doing the rear diff it also made sense to me to fit new callipers, discs and pads all round, Timken wheel bearings all round, Ashcroft rear HD drive shafts and flanges, replace the SS boost pipe hoses with Samco XDB ones, fit the Eberspacher heater in the under cubby heater box, fit the nakatanenga fuel tank pick up pipe( rear wheels are off giving better access), fit an additional fuse box and once that's done give the underside its yearly coating of waxoil. Amazing how much extra gets added to the list when all that was needed was a simple diff swap!! Rolling Eyes
Post #431779 17th Jun 2015 10:06pm
fathaggis
yesterday i fitted a RTC damper and steering guard . i went for the steering guard as i didn't
like the look of the full face ones and yes the dog is cleaning the tyres Very Happy Dog
and today i fitted new headlights (non e mark)
[url][/url]
Post #431944 18th Jun 2015 5:31pm
Brian / lorryman - you'll be busy - 3 days!! MAre you dropping the tank? Not as bad as you may find.
I'm waiting on CVs too ... Cool
Post #431948 18th Jun 2015 5:38pm
Lorryman100
@bpman: No need to drop the fuel tank with the Nakatanenga fuel pick up. It fits between the top hoses with an internal pipe that feeds down into the fuel tank Thumbs Up
http://nakatanenga-tours.de/shop/article_T...%2520LR%26
Post #431979 18th Jun 2015 7:57pm
Put this back on after ages, nothing exciting really but I had to repair the panel as it was bent in!
That'll be the last time I tow anyone out of a pickle though goodwill. Rolling Eyes
The good news is it's back to perfect. Smile
Post #431985 18th Jun 2015 8:15pm
Defpuma
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
That time of year again so went down for the MOT - passed again with no advisories! Well pleased!
Post #432026 18th Jun 2015 10:13pm
SailingTom
Bit of a rebel with that and the naughty number plate then! Laughing
Nothing on mine, but found some oil starting to go through the loom. So will try and get that sorted while its in the early stages.
Post #432032 18th Jun 2015 10:23pm
Lorryman100
Fitted the Ashcroft ATB into the rear axle.
Post #432241 19th Jun 2015 9:08pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Jasmin sacrificed a front hub complete to enable a mate to go on his little holiday, still Jas gets a nice shine set of led headlights soon as a thank you.
Post #432291 20th Jun 2015 12:44am
