Home > Technical > td5 rev counter
wizz80
td5 rev counter
Is it a easy job to fit a rev counter to a td5 I'm sure I have seen one fitted but can't remember who or where I saw it
Post #428606 4th Jun 2015 4:30pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Post #428611 4th Jun 2015 4:48pm
gilarion
Easy, though not as easy as some engines where you only need to take a feed off the 'W' connector from the alternator and find a live and earth
On a TD5 you need a special loom, which is usually supplied with the rev counter, the loom has a little black box attached which requires an ignition feed and earth. Also you need to connect a ECU input to the black box on the loom which produces an output for the Rev Counter.
The wiring loom obtains its live from the live feed from the ignition barrel, earth from the steering column support or a good known earth; you can obtain an illumination for the gauge from another gauge in the instrument surround.
You run the wire from the ECU under the seat to behind the instruments, this feed goes to the little black box and the output wire from the black box goes to the Rev Counter. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #428613 4th Jun 2015 4:58pm
Fatboy Slim
Wales
If you can find a genuine LR one its easy peasy
Not cheap though.
Post #428629 4th Jun 2015 7:33pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I fitted a genuine one, very easy, I used a Croytec loom which was very useful as it also came with all the instructions etc.
I'd recommend getting one, probably an hour or so to fit.
Post #428643 4th Jun 2015 8:31pm
jst
i used a gen td5 one for about £50 (a while ago this was) then +_ve and -ve and and ECU Pin, (pin 18 was it?) maybe 19?..... 30mins work. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #428660 4th Jun 2015 10:27pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
As jst said easy to do your self pin 19 feed earth and ign live some models already have the wire up behind the dash so check the plug first if it's got a wire in it then trace back behind dials and easy 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #428679 4th Jun 2015 11:41pm
wizz80
Good stuff sounds easy enough will have to see what the chap who wants it fitted wants to spend
Post #428847 5th Jun 2015 5:43pm
