![]() | Home > Technical > td5 rev counter |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5138 ![]() ![]() ![]() |
Easy, though not as easy as some engines where you only need to take a feed off the 'W' connector from the alternator and find a live and earth
On a TD5 you need a special loom, which is usually supplied with the rev counter, the loom has a little black box attached which requires an ignition feed and earth. Also you need to connect a ECU input to the black box on the loom which produces an output for the Rev Counter. The wiring loom obtains its live from the live feed from the ignition barrel, earth from the steering column support or a good known earth; you can obtain an illumination for the gauge from another gauge in the instrument surround. You run the wire from the ECU under the seat to behind the instruments, this feed goes to the little black box and the output wire from the black box goes to the Rev Counter. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
If you can find a genuine LR one its easy peasy
Not cheap though. |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
I fitted a genuine one, very easy, I used a Croytec loom which was very useful as it also came with all the instructions etc.
I'd recommend getting one, probably an hour or so to fit. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8391 ![]() ![]() ![]() |
i used a gen td5 one for about £50 (a while ago this was) then +_ve and -ve and and ECU Pin, (pin 18 was it?) maybe 19?..... 30mins work. Cheers
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
As jst said easy to do your self pin 19 feed earth and ign live some models already have the wire up behind the dash so check the plug first if it's got a wire in it then trace back behind dials and easy 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
wizz80 Member Since: 06 Dec 2012 Location: north devon Posts: 38 ![]() |
Good stuff sounds easy enough will have to see what the chap who wants it fitted wants to spend
