![]() | Home > Maintenance & Modifications > Throttle potentiometer bolts removal? |
| RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144
Any tricks on this removal? The 2 bolts on the throttle potentiometer keep spinning!
now I can't get if off the foot wall, and can't get it tighten it back ![]() |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
You need a Helping hand on engine side with a spanner Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
Oh I see...
Thanks, will look for a hand to do that so! Should I look for the Nuts from under the vehicle? or from under the bonnet? |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
Under the bonnet, Ive done it a few times on my own as described above
Thank you!
| All times are GMT |
