Home > Maintenance & Modifications > Throttle potentiometer bolts removal?
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
Any tricks on this removal? The 2 bolts on the throttle potentiometer keep spinning!
now I can't get if off the foot wall, and can't get it tighten it back Mr. Green
Post #427365 31st May 2015 6:50am
dgardel
Italy
You need a Helping hand on engine side with a spanner Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #427378 31st May 2015 8:13am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
They're not captive nuts, so will turn as you've found.
Even if you're on your own, you can carefully put a 13mm (from memory) ring spanner on the nuts from the engine bay side.
Then go back into the car and using a socket, slowly, not pushing or pulling, undo or do up the nut.
The spanner will move and jam against a bit of bulkhead, hold the nut and the job's done.
You might have to do this a few times to Make it work.
Or get someone else to hold the spanner as the gentleman says above. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #427389 31st May 2015 8:55am
RF3777
Oh I see...
Thanks, will look for a hand to do that so! Thumbs Up
Should I look for the Nuts from under the vehicle? or from under the bonnet?
Post #427404 31st May 2015 9:36am
AndrewS
Under the bonnet, Ive done it a few times on my own as described above Thumbs Up 130's have feeling's as well you know Smile
Post #427437 31st May 2015 10:37am
RF3777
Thank you! Mr. Green
Post #427669 1st Jun 2015 2:12am
