Home > In Car Electronics > Single DIN fixed Nav systems
CarlS
2016 Defender 110 Puma 2.2 XS CSW Aintree Green
I'm starting to hunt around for some new sound system stuff. I'm after a fixed nav system that'll go in the standard DIN, I'm not that fussed on the 2 DIN upgrade.
One system I've found is this Clarion one, does anyone have any experience with this one? http://www.caraudiocentre.co.uk/product_m-...-27662.htm
Another I've found is the Audovox one, the software looks a bit dated but looks ok.
http://www.caraudiocentre.co.uk/product_m-...-26720.htm
Can any recommend a similar system?
Other upgrades I'll be looking to do (ones I've seen on here) include hanging a Kenwood underseat sub off the back of the cubby box & the Focal speaker upgrade. The spawn of AndrewS
2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead
2016 Mini Countryman Cooper S All 4
2019 BMW R1200 GSA Rallye Sport
Post #426502 26th May 2015 8:44pm
Out of those two I'd go for the Clarion,,heard good things about it. Thumbs Up
Post #426549 26th May 2015 10:28pm
TJ101
Carl
Could have had a look at the one i have fitted when you poped in !!
Pioneer AVIC unit
Had one in the 07 years ago,, that survived the dust in Morocco well, so updated it 3 years ago, and now in the swapped into the new one
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #426555 26th May 2015 10:49pm
Likeomg
have the clarion one....
excellent bit of kit.
Post #426556 26th May 2015 10:52pm
Clarion / Pinoneer, all good premium brands. Thumbs Up
Post #426561 26th May 2015 11:32pm
CarlS
Nice one guys, I've pretty much got my head set on the Clarion one, it seems to be a good price with all the bits.
The Pioneer one starts to get a bit pricey when you start adding the nav add ons & cameras ect.
I didn't realise Tim, I should've had a bit more of a nose around your truck! Wink The spawn of AndrewS
Post #426575 27th May 2015 7:15am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
The downside of the Clarion is you can't change the blue lights into green.
Post #426578 27th May 2015 7:52am
CarlS
I prefer blue Wink The spawn of AndrewS
Post #426907 28th May 2015 6:17pm
smb
The Clarion unit is excellent and absolutely brilliant if you have the TV unit. However, if you have the tv unit, sub unit, iPod connection, external mic unit etc...it is an absolute pig of a job to fit it in a Puma with all the cables and plugs/sockets at the back of the Clarion and the Vent pipes of the Puma. It takes a lot of patience and scraped knuckles and a few plasters too Crying or Very sad
Post #426916 28th May 2015 7:17pm
CarlS
Thanks for the heads up smb. I fitted a head unit in my tdci 90 a few years back that was full of leads at the back & it was a nightmare fitting it all in, like you said.
I'll hopefully get around to ordering it all up this weekend. The spawn of AndrewS
Post #426945 28th May 2015 8:55pm
Out of interest where are the rest of you routing your cabling if you have external units to fit?
Mines running mostly drivers side down the void to the footwell area but under the mat to between the handbrake to cubby.
Then under the cubby to the rear area.
Post #426949 28th May 2015 9:04pm
CarlS
Yea I used to do it as you've said above mostly.
You could run cables out through the bulkhead and down on to the chassis rails to the rear & back into the body. The spawn of AndrewS
Post #426956 28th May 2015 9:20pm
There could be better ways of routing it really but the plugs are too large to thread through and you wouldn't want to cut them off just to thread through to re-solder. Then of course you can't remove it either.
Post #426965 28th May 2015 9:58pm
CarlS
We've gone down the back of the dash & out through the the transmission cover to rear before. That was from switching on the dash to inverter relays, amp, under seat sub & a few other things towards the back of the 130.
Ordered up the Clarion head unit earlier with the Kenwood under seat sub for now. I noticed its DVB-T ready? Anyone know what that means? Googled it, something to do with t.v? The spawn of AndrewS
Post #427171 29th May 2015 10:56pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Means Freeview TV I think Thumbs Up
Post #428272 3rd Jun 2015 8:55am
