cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Yesterday i polybushed the rear radius arms and one of the front ones aswell, just need to do the other radius arm and the pan-hard rod then they are all done
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Fitted some Dynamat.
Only fitted three sheets so far on seatboxes and noticed an approx 1 - 2 dB reduction in noise at idle as I tested before and after. In the exact same location iPad placed etc 71dB prior approx 69 / 70dB after. More to fit tomorrow. Only done the bases of seatboxes and two seatbox sides on the top and side so not much yet really. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
Tidy job steve, i used 4 boxs on my 90 and 7 rolls of foam
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
The best thing about waxing the Landy is this
![]() Click image to enlarge ![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I cant view the video, but the effect you are describing might be caused by the image stabilisation capabilities of the camera/phone. Bizarrely when you get a certain vibration in the vehicle, you will get a wobble as the image stabilisation tries to compensate. You could try turning that feature off and see if it makes any difference. cheers simon |
Dropped the red 90 off for a couple of days worth of investigation into it's newly acquired electrical gremlin.
Drove out in Disco Sport and I must say it is far better than the pre production version I drove six months ago. The power steering is far more balanced and the interior finish is good. Engine is a bit gutless in second gear but the drive is OK. Managed to give it a good test as the A303 was closed with a multi vehicle accident so a 20 minute drive home turned into an hour and a half on the back lanes. Still won't buy one, I still prefer the Ewok ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
ipad/phones tablets are not accurate. I doubt it is within 10db of accuracy ![]() |
True but a rough guide at least.
Got waved at by a driver of a matt pink Evoque.
Spotted 2 x Disco sports Took a washing machine to the tip. Cleaned the windows on the 110 (again) Ordered new wiper blades (Bosch ones this time instead of BlueCol ones) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Done a bit more:
![]() Click image to enlarge ![]() Click image to enlarge I've got the corner protectors to go in tomorrow, only bought them yesterday! |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
Good close up pics of corner protectors installed would be good.
Thanks, Pickles. |
Pickles - I'm fitting them tomorrow so I'll 'PM' you a few photos if that's helpful.
Hopefully I'll remember. ![]() I got them from LRi on eBay but they are made by YRM so you can buy direct too I think. |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
+1 recommendation for the corner protectors, great little mod.
Doubled up my reverse and fog lamps. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3675 ![]() ![]() ![]() |
Went to Machynlleth and then Newtown in Wales was averaging 35mpg on the B roads according to the scan gauge but dropped to 20mpg on the M54 and M6 at 70mph on the way back. Now up to 14k miles and seems to be running better than ever, transmission is definitely much tighter and gear change better since the clutch and g/box to t/box shaft was replaced.
![]() I hope everyone is well and your land rovers make you happy |
