Home > For Sale & Wanted > [For Sale] Puma 4 pin diff
A low mileage (16k) 4 pin diff taken out of my 2010 defender, it has been run in synthetic gear oil or the last 11,000 miles
Perfect working order, Removed due to an upgrade
£200 Ono ..
Post #425838 24th May 2015 7:52am
Assuming it is a front diff, I am interested please. I am away at the moment but will pm in the week if that's OK. Thanks.
Post #425937 24th May 2015 5:32pm
sorry BW it's a 4 pin rear (are they different?) , I'll have a front one in a months time, not sure if its a 2 or 4 but coming out of 2010 110.
I'll pop a photo up later if you like
Post #426050 25th May 2015 8:29am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Fronts are standard 2-Pin, rears are 4-Pin.
The rear 4-Pin can be put in the front but need machining to fit.
Post #426081 25th May 2015 10:50am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Do you ever come up to Hertfordshire/Bucks? I believe this would fit a TD5 110... Question
Post #426096 25th May 2015 11:39am
Cupboard
I thought they changed them at some point?
Post #426103 25th May 2015 12:24pm
T1G UP
2 pin in the front
Post #426106 25th May 2015 12:44pm
From what I have read, LR put 2 pin in the front and 4 pin in the rear, then there was a change of plan (2009/2010) and they started to put 4 pins in the front of 110/130s but kept putting 2 pins in 90s.
I'm not sure what's in mine,, but defo a 4 pin came out of the rear on Saturday.
Post #426143 25th May 2015 4:17pm
Many other threads on this.
90 front - Rover pattern 2 gear diff, all models.
110 front - Rover pattern 2 gear to sometime in 2010, then 4 gear Rover.
90 rear - Rover 2 gear all models
110 rear - P38 4 gear all models
130 is the same as 110.
It's a Rover pattern 4 gear diff I'm after if the price is right.
Post #426244 25th May 2015 10:08pm
newhue
Australia
Thats my understanding. My April build 2010 has a 4 pin in the front. My Defender and travels
Post #426268 26th May 2015 1:24am
Caterham
well my MY11 that I picked up in late Oct 2010 has a 2 pin at the front Sad
newhue - if you are right it kind of confirms what I thought. mine was an extra one they built from the spares bin. Neutral
Post #426281 26th May 2015 7:17am
newhue
Australia
To be clear as someone on here corrected me. Two pin is actually one, and what we are calling 4 pin is actually two. I also have a 2 pin (known as 4) front centre from a 2010 110 a mate gave me. Maybe it's an OS spec.
Down here some bloke in a Puma ran off the road because his 1 pin front diff seized. There was a period where the dam pin was coming loose and seizing the diffs. There was more than one instance I believe. I am amazed how this could be, the ramifications for JLR I would have thought should have sparked a recall for an immediate check. I guess no one was seriously injured so no hurry, just maybe during standard servicing checks were done for its placement.
You can check what you have using a torch through the fill hole. Are you sure you don't have a two pin.
If you think yours was made of spares, how do you think I feel, mine has build date April 1. And when it went pear shaped on day 2 of ownership I was somewhat numb and in denial. My Defender and travels
Post #426356 26th May 2015 11:16am
Caterham
oh dear Crying or Very sad .... don't tell me April 1 was also a Friday ?
yes if you know what to look for you can determine the type via the oil filler.
blackwolf kindly sorted the info out for me to determine which is which....I'll go see if I can find the link.
check out page 2 - http://www.defender2.net/forum/topic25075-15.html
Post #426358 26th May 2015 11:33am
^^^ Which is precisely why I always refer to them as "2 gear" and "4 gear.
My original 2 gear front diff (2007 110) failed exactly ad you describe. Interesting to say the least since it becomes virtually impossible to steer. Fortunately it was a very wet day so some scrub was achievable.
Post #426360 26th May 2015 11:43am
newhue
Australia
SNIP
Na mate it was a Thursday. Just before Good Friday so close enough to a Friday. My Defender and travels
Post #426497 26th May 2015 8:26pm
