Home > Maintenance & Modifications > Wooden interior
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Wooden interior
Has anyone thought of adding a wooden floor in their Land Rover like BLR or the other bespoke LR people?
Post #311110 23rd Feb 2014 11:10pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Like this? Mr. Green
Still have plans for a custom cubby box made of some special wood, but not for the floor inside the crew cab. I'm trying to get the noise level down a bit. A wooden floor probably wouldn't help.
Post #311122 23rd Feb 2014 11:34pm
Killer90
Site Sponsor
I have some going in my new 90 Charlie Thumbs Up photos to follow chap Mr. Green CSK Automotive
www.cskautomotive.co.uk
Post #311126 23rd Feb 2014 11:38pm
SailingTom
Ill also be fitting out my next one as might over order for the next boat im doing Whistle Defender puma dormobile camper
Post #311127 23rd Feb 2014 11:39pm
ericvv
[quote="tookaphotoof"]Like this? Mr. Green
Thumbs Up That has a very significant WOW factor to it. Lovely truck, searched your gallery for some more pictures of this 130, but there aren't many.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #311165 24th Feb 2014 5:49am
charliebaja
What wood is that?
Post #311170 24th Feb 2014 7:34am
SailingTom
In another post he mentioned it was Iroko, a lovely wood to work with having simular properties to teak so very hard wearing. It will go darker as it gets older but ideal for that type use. Thumbs Up Defender puma dormobile camper
Post #311171 24th Feb 2014 7:44am
tookaphotoof
I could splash a couple of buckets of sea water in the back and give it a good rub. A good way of getting the original color back, although I'm fairly sure it wouldn't do good for the rest of the car.
Anyways, left the wood untreated so it can age nicely and I don't have to be too careful with it.
For anyone considering a wooden floor don't forget cargo rails.
I have two on the floor and one on each side and it makes life so much easier than jus a couple of rings to get your load fixed. The 130 didn't even have one single fixing point. Rolling Eyes
Eric, not too many photos, but from the outside the car looks completely standard. There should be one or two photos from an adventure weekend on this forum and you could look up my name on Flickr. I have some up there as well.
Post #311179 24th Feb 2014 8:54am
leeds
Like this? Whistle
Do not need to be a master carpenter.
Brendan
Post #311186 24th Feb 2014 9:57am
leeds
And it's type approved by Lloyds of London as decking, so you could even take it wading Rolling with laughter Rolling with laughter
Barbara
Post #311215 24th Feb 2014 11:52am
charliebaja
I was thinking that I would remove the horrid chequer plate that is fitted and Dynamat it all then apply the wood on top, which i presume is just glued in?
Post #311737 25th Feb 2014 11:48pm
SailingTom
Thats it, you can glue it in or you could screw it. Ill do mine so its removable though as it will just be the floor section like Barbara and Brendon's, might do it a bit more snazzy like TookaPhotos' one though with edging, might get a shape in the middle too, but have to wait and see Wink
Like B&B say though its not that hard more time consuming, but you can always do it simply in straight planks which looks good as above or go the full works like the 130 for the wow factor. Just depends how much time you put into it.
Cheers Tom Smile Defender puma dormobile camper
Post #311840 26th Feb 2014 11:51am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Tek-Dek is easier to work, and lighter, than the real thing. But still pretty expensive…
Don’t bother with anything like that for my truck, but my Mog has wooden floor, bulkhead, door frames and body tub as standard, while you guys are playing with Dinitrol, I’m lying on my back brushing on Cuprinol!
Peter
Post #311908 26th Feb 2014 5:07pm
WOODEN RANGE ROVER IN KENYA
Why stop there?
https://akinyiadongo.wordpress.com/2012/01...-in-kenya/
Post #423146 13th May 2015 10:10am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
This is the Oak floor I put in my defender
 Original Member Pie n Pea Club.
110 HCPU Tipper
Post #423159 13th May 2015 10:57am
