![]() | Home > Maintenance & Modifications > Wooden interior |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
Has anyone thought of adding a wooden floor in their Land Rover like BLR or the other bespoke LR people?
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Like this?
![]() ![]() Click image to enlarge Still have plans for a custom cubby box made of some special wood, but not for the floor inside the crew cab. I'm trying to get the noise level down a bit. A wooden floor probably wouldn't help. |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
I have some going in my new 90 Charlie
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
Ill also be fitting out my next one as might over order for the next boat im doing
[quote="tookaphotoof"]Like this?
![]() ![]() Click image to enlarge ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
What wood is that? |
In another post he mentioned it was Iroko, a lovely wood to work with having simular properties to teak so very hard wearing. It will go darker as it gets older but ideal for that type use.
I could splash a couple of buckets of sea water in the back and give it a good rub. A good way of getting the original color back, although I'm fairly sure it wouldn't do good for the rest of the car.
Anyways, left the wood untreated so it can age nicely and I don't have to be too careful with it. For anyone considering a wooden floor don't forget cargo rails. I have two on the floor and one on each side and it makes life so much easier than jus a couple of rings to get your load fixed. The 130 didn't even have one single fixing point. ![]() Eric, not too many photos, but from the outside the car looks completely standard. There should be one or two photos from an adventure weekend on this forum and you could look up my name on Flickr. I have some up there as well. |
And it's type approved by Lloyds of London as decking, so you could even take it wading
![]() ![]() Barbara |
I was thinking that I would remove the horrid chequer plate that is fitted and Dynamat it all then apply the wood on top, which i presume is just glued in?
Thats it, you can glue it in or you could screw it. Ill do mine so its removable though as it will just be the floor section like Barbara and Brendon's, might do it a bit more snazzy like TookaPhotos' one though with edging, might get a shape in the middle too, but have to wait and see
![]() Like B&B say though its not that hard more time consuming, but you can always do it simply in straight planks which looks good as above or go the full works like the 130 for the wow factor. Just depends how much time you put into it. Cheers Tom ![]() |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 886 ![]() ![]() ![]() |
Tek-Dek is easier to work, and lighter, than the real thing. But still pretty expensive…
Don’t bother with anything like that for my truck, but my Mog has wooden floor, bulkhead, door frames and body tub as standard, while you guys are playing with Dinitrol, I’m lying on my back brushing on Cuprinol! Peter |
Why stop there?
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge https://akinyiadongo.wordpress.com/2012/01...-in-kenya/ |
This is the Oak floor I put in my defender
![]() Click image to enlarge Original Member Pie n Pea Club. 110 HCPU Tipper |
