Home > Land Rover Customer Relations > 2.2 TDCI Recall for oil pump failure
Page 4 of 7 <1234567>
CRC@LandRover
Verified Account
Verified Account
Hi Jukathy
Thank you for your post.
It has been identified that the pumps fitted on the vehicles in the specified VIN range may experience a concern which is the reason for the launch of the relevant Service Action.
Land Rover have no reason to believe that vehicles with a chassis number outside of the specified range are affected, therefore there is no requirement to change the pump on vehicles that fall outside of this VIN range.
However, should you have any concerns we would suggest visiting your local Land Rover retailer who will be able to inspect your vehicle and advise accordingly.
Regards
Ryan
Post #421740 7th May 2015 9:22am
Jukathy wrote:
Ryan@LandRover wrote:
The VIN range is: LD405037 - LD443988
If you have not been contacted and your vehicles VIN falls between this range, please contact your local Land Rover approved retailer and provide them with your VIN for ... clarification as to whether your vehicle requires Q421.
Many thanks,
Pete
Hi Pete
Mine is not listed in Topix. Now I'm having concerns since it is mid 2012 (LD42....)
Do I read your statement correctly, if I'm saying that only special customers are going to receive the new oil pump?
And other costumers do not require Q421? And therefore have to rely on the dysfunctional pump?
And how could that be - if the oil pumps from MY 2012 are identical?
Otherwise, your statement would be more about the clarification if Q421 is still outstanding - or has successfully been completed before. Did you say it like this?
Thanks in advance for your clarification.
Julia
Julia, I understand your question - it looks like your VIN is well within the range that is subject to the service action.
I'd ignore whether or not you can find it on TOPIX and get it booked in for the new parts under this service action. They will take your VIN and check again online to see if it's subject to the recall. It's unlikely that's it's already been done as it is a "new" issue or rather a "new" fix.
If they reject it they will give you a reason, i.e., your VIN is outside the range and maybe you have mis-read it. As i see it that's the only clarification available. There are no special customers Laughing
Post #421764 7th May 2015 10:58am
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
Okay, I'm going to get in touch with the local Land Rover retailer.
Thanks, Ryan & Supacat. Great. Thumbs Up
Post #421804 7th May 2015 2:21pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Appears that LR Southern Africa is keeping quiet about this.
Only after I mailed them a screen grab from Topix (big thanks to Bob), did they respond.
They used my engine number, rather than the VIN.
"Good day you need to supply me with the engine no on the front of the timing cover it is only vehicles with post130909202010 do not install an oil pump.
Pre130909202010 needs the oil pump replacement."
Post #422562 11th May 2015 9:06am
Let us know how you get on.
Post #422570 11th May 2015 9:57am
Jim_Bean
Just had mine done. Took several hours. Hopefully no leaks will now appear.
All shiny now Very Happy
Post #422835 12th May 2015 11:25am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Mine will be fixed next week. Thumbs Up
Post #422854 12th May 2015 12:28pm
Kitoper
Switzerland
Heads-up -
As of today, LR Switzerland has acknowledged and published on the Topix site the Outstanding campaigns for Defenders within the Vin Range for the Q421 Oilpump failure.
The picture below speaks for itself and I will be following up with the local dealer.
Post #422876 12th May 2015 1:26pm
oburrill
United Kingdom 2013 Defender 110 Puma 2.2 SW Corris Grey
Hi, I've just had mine in for the Q421 oil pump replacement. But I questioned them about the sump and other parts and they said it was just the oil pump, oil and filter.
I read on here that it was also the sump, pump pickup and outlet pipes etc.
What do think?
I've dropped a message to the dealers and will see what they say.
Just for peoples reference, I received a text message for me to contact the dealers, not a letter, and then they told me that I needed to bring it in for the oil pump.
Thanks.
Post #424275 17th May 2015 8:44pm
GUM97
They've lied to you. Here's a list of exactly what should be changed, and if they haven't changed ALL of these parts correctly, then you need to be having stern words with them!
Pete An engine to TDi for!
Post #424290 17th May 2015 9:19pm
oburrill
Hello. Thanks for the quick reply.
I'll be giving them a ring tomorrow.
This is why I wanted them to put it on paper what has been changed.
Thanks again.
Post #424295 17th May 2015 9:27pm
CRC@LandRover
Verified Account
Verified Account
Hi oburrill
I note that you are due to speak to your retailer to confirm what was completed during the recent Service Action on your vehicle and trust that they will be able to clarify this.
However, should you require any additional assistance, please feel free to send me a PM and I will be happy to look into this for you.
Regards
Ryan
Post #424402 18th May 2015 11:55am
lohr500
Hi oburrill
If you have the vehicle back with you take a quick look underneath. There should be a shiny new sump as shown in the photo in the earlier reply.
I picked mine up on Friday after the oil pump replacement work was completed (and some other work to try and stop the footwell leaks). There is certainly a new sump on my engine.
Post #424578 18th May 2015 8:59pm
oburrill
Hello, thanks for the email Ryan, it's good to know that there is help there when needed.
I sent an email last night and rang the service supervisor, who I spoke to when I took it in the other day, and he said that he had it on his desk to double check and look through today and he'll let me know. On the day I asked him twice, about the sump and other parts, but said it wasn't needed.
I send him the list as mentioned here, and I questioned him about it and said that they would have fitted all the parts required as part of a kit supplied to do the work.
I've not had a reply from him today, and I phoned up just after 8.30am, but I can't check my emails at work, so have just checked now.
To me it doesn't look like they've changed the sump, as the old sump had waxoil splattered on it, and it still does. See the attached photo.
It is about 20 to 30 mins drive from the dealers, so its not dirty and it is definitely wax oil splatter that is on it. They may have changed the sump plug and put a pen mark on it.
Hang on a minute, I need to have a look how to upload a photo, as I mentioned, its not shiny and it still has waxoil on it!
Thanks everyone.
Post #424590 18th May 2015 9:11pm
Jim_Bean
That is definitely not a new sump. Mine was very obviously brand new and VERY shiny.
The dealer is definitely trying to cut corners. I would question if they replaced anything or just gave your engine sump a quick wipe with an oily cloth!
Should look like this :
Post #424704 19th May 2015 9:24am
