![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Some more bits arrived today.
![]() Click image to enlarge I'll see how long the hinges stay tight and if they don't last I'll get some of the orp ones. The old door waist seals were past their best ![]() ![]() Click image to enlarge The new ones were described as oem but aren't exactly the same and needed some trimming here and there to fit but it looks tidier than before ![]() Thanks for looking, all comments welcome. Ray My build thread http://www.defender2.net/forum/topic17615.html |
I went for the YRM Safari Door Hinges as the ORP ones were a little too far off OEM. Three letter abreviations don't you just love 'em?
![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
![]() ![]() Edit: I'd have to get the orp ones painted if I got them so they didn't stick out as much. Ray My build thread http://www.defender2.net/forum/topic17615.html |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733 ![]() ![]() |
Where did you find the window rubbers as need to get 2 new back ones for mine.
Like the updates, got a few ideas I'll have a go at from this thread. ![]() |
![]() http://www.sp-4x4.com/DEFENDER_110_DOOR_SE...lr5982.htm Ray My build thread http://www.defender2.net/forum/topic17615.html |
Fitted the new hinges and the stainless nakatanenga bolts today.
![]() Click image to enlarge I knew the old hinges were shot but putting the new ones on lifted the door about 1/2 an inch ![]() Old rusty worn out ones even after I fitted new bolts and brass inserts last year ![]() ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
Big thanks to buckblu110
![]() Poor eBay pic. ![]() I've been looking for one for the last few years after seeing tj101's 110 on here as I love the look but the wrap around ones never seem to come up for sale. It needs a bit of repair but I got it for a good price so just a 6 hour round trip to pick it up on Friday and then a bit of work fixing ![]() My build thread http://www.defender2.net/forum/topic17615.html |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 736 ![]() ![]() ![]() |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Great find. They do look great. What is the damage it has sustained? 2002 110 td5
There was only one small pic of the damage but it looked like a couple of cracks on the top that had had some plastic filler poorly put in then not rubbed down
With the spacers came the usual muck thrown up the sides so I popped over to mud this afternoon to pick these up
![]() Click image to enlarge Just getting them painted and I'll get them fitted in the next couple of days ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Hopefully no more mud up the side
![]() ![]() Click image to enlarge Just waiting for some bolts too arrive then I can raise the rear mud flaps a couple of inch which should also help Ray My build thread http://www.defender2.net/forum/topic17615.html |
Raise the flaps Ray or move them out? I moved mine out to prevent muck spray about 1-2"
![]() And no that isn't a midget in my passenger seat. Damn cyclists..... ![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
![]() ![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
Light force spots, soo much better to look at than an LED light bar !
