Home > Maintenance & Modifications > Wheel respray/powdercoat cost?
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
As above, what would it cost to get 5 wheels done, no damage to sort or dents, just to paint or powdercoat, and will they remove the tyres from the rims if just doing a respray?
Post #421179 4th May 2015 9:30pm
camelman
I've had 2 sets done over the last couple of years at £35 a wheel, the tyres need to come off to do it properly and you'll usually have to sort this yourself.
Post #421186 4th May 2015 10:02pm
K9F
As Camelman stated £35 per wheel is about right no tyres fitted. I paid similar when I had mine done. Thumbs Up
Before....
After....
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #421189 4th May 2015 10:06pm
gumdrop
CAS Coating in Bradford www.cascoatings.com charge with prices starting at £1 per inch - 16" wheel £16. You have to supply with out tyres and any scuffs repaired. I have 5 Freelander wheels done a couple of years back in Silver Sparkle - excellent. Cheers
Simon
50th D90 - my toy!
Freelander SE Td4 3 door - local run around
1958 Series 1- Rag top!
Post #421194 4th May 2015 10:32pm
SailingTom
My Painter is 50 a wheel. He does a fantastic job though. I prefer to have wheels painted than powder coated as maintanance is much easier.
Tyres need to be removed for either though to get a quality job. Thumbs Up
Post #421222 5th May 2015 6:41am
K9F
I've never tried painting only powdercoating. The ones that I have recently taken off after over 5 years of fitment I was going to have refurbished but once cleaned and the weights removed they don't need it. Powdercoating to be resilient and effective must be done correctly by a reputable coaters or it can peel off in sheets if moisture finds it's way in.
Post #421245 5th May 2015 8:58am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
I had a set of five 16" Landy alloys Blasted and powder coated about a month ago, £35 a wheel, plus or minus Vat depending how ya pay Whistle
Mine where gunmetal grey finish, I'm really chuffed with um Very Happy
Post #421376 5th May 2015 6:25pm
Lambley
Thanks for the replies, it's less than I was expecting to be honest, I thought it'd be £50/60 per wheel, I've been looking at some anthracite Boosts on eBay, they seem to be expensive for what they are, even though they look nice, I'd be better off buying some loose wheels and getting them sprayed, or doing it myself and investing in a spray gun, I've got a compressor etc, just not done any fine paint work....
Looks like they've either sold or been removed now anyway....
http://www.ebay.co.uk/itm/Defender-wheels-...7675.l2557
These also seem like good value, even though the tyres are fitted, a mate of mine would take all of them off and refit for a twenty spot...
http://www.ebay.co.uk/itm/111640787196?_tr...EBIDX%3AIT
Post #421381 5th May 2015 6:44pm
