Page 803 of 1394 <123 ... 802803804 ... 139213931394>
walfy
Well today and yesterday I went to the local dealer in Brizzle. Spent all day there and they sent me away with a pocket full of money Thumbs Up Thumbs Up Thumbs Up
All I had to do was teach a bit of first aid to the staff there. Need to go back and complete the final assessments later this week or early next.
Happy days 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #418044 21st Apr 2015 9:31pm
Tis' a nice dealership if only it was in a slightly better less busy location. Thumbs Up
They've done a good job with mine there and I didn't feel,like you were looked down upon if a suit walked in.
Post #418061 21st Apr 2015 10:04pm
JWL
After finding a slight disadvantage of the electric RX8 seats, they're designed to get up out of not slide down and out, I fabricated a bar that fits on the side to stop me destroying the plastic side panel and switches. It works by being around the same height of the plastic trim on the side so I can slide out of the seat and over the bar without putting any weight on the plastic. Seems to be OK and not too out of place, another advantage is that the seatbelt is kept away from the door catch, anything to stop it from keep being snagged in the door catch when the door is closed.
Post #418063 21st Apr 2015 10:06pm
The seat base bolster height is higher I expect?
Post #418079 21st Apr 2015 11:15pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
Went to Preston and back, around a 180 mile round trip on the M6. Loving the Puma, and the BAS remap, didn't miss a beat sat effortlessly up the outside lane most of the way, no comparison against the older models when at motorway speeds for a long time. Thumbs Up Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #418093 22nd Apr 2015 1:32am
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Yeah thats something i need to do just need to look for the right rock / tree slider that act's as a step aswell Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #418140 22nd Apr 2015 11:21am
roel
Working on it:
From this:
To this current state:
Getting closer. Roel
2003 90 Td5 (2009-now)
Post #418196 22nd Apr 2015 5:32pm
LR90XS2011
looking very tough DEFENDER 90 TDCI XS,
Post #418199 22nd Apr 2015 5:41pm
JWL
Graham, all I did was attatch a bit of round tube bent to follow the seat.
The rocksliders are made by me and I fix what's left of the original folding side steps with a couple of bolts to make getting in and out easier. Only 5 minutes to take them off when needed.
Post #418224 22nd Apr 2015 7:55pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Passed the 5000 mile mark 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #418230 22nd Apr 2015 8:17pm
cornish rattler
Are right i see, thought you mean't climbing in and out as i find i need a step to help getting in and out of the 90 but more for getting in but then i do have 265 special tracks fitted aswell which doesn't help, think a decent rock / tree slider where i can use as a step aswell should do Thumbs Up Graham
Post #418343 23rd Apr 2015 11:24am
JWL
Good luck Graham as when I was looking round there are plenty of sliders about but with doing a school run I wanted a means of a step below the cill height and that's where I decided to make my own. Yes I could have left the folding steps under the sliders but the whole point was to give protection to the vehicle and I've lost count of the number of times I have had to straighten out mangled steps that were in the "up" position. Personally I'm not a fan of round tube on a Defender hence the square sliders(plus that's what I'd got to hand) and the steps are the old folding ones dismantled down to just the treadplate with a couple of bits of angle welded on to poke up through the gap between the outer bar and the cill box section and just a bolt through that tightens up against the main box section to keep them in place and stop them rattling. All very agricultural but serve a purpose.
Post #418356 23rd Apr 2015 12:15pm
custom90steve wrote:
Took off my rear wheel arch spat for a reason today.
Can you spot the problem left?
I can sort it, but goes to show that I did have to replace it to sort this out.
Then the CP will have to come off first and probably the rear quarter protection too.
If it wasn't for the CP and protection there this would have been much worse.
Slight update on this although not that exciting.
Took off the rear quarter step / guard no probs. The CP was a pain due to silicone but done now.
Got the panel edge straightened no problem as its all hidden anyway it's not much to worry about asthetically.
So now it's perfectly straight again as it should have always stayed. Rolling Eyes
New arch spat fitted on that I got from breakers, all good bar it's silver not Stornoway which is as it was sold its difficult to tell the difference.
Anyway, will take it off soon for matching paint then fit all the bits back and that should be that.
Didn't want to go about with a panel slightly out of true and a crack in the arch but it's only taken me nearly two years to get around to sorting it. Laughing
Post #418517 23rd Apr 2015 10:42pm
Fitted LED side repeaters
New Obdii tool arrived, will be playing at the weekend Mr. Green
Post #418520 23rd Apr 2015 10:49pm
BP - I got a pair of those I've not long fitted too. Nice aren't they!
They work better integrated with the other LED's I think as well, pretty obvious really as a mix of incandescent and LED aren't going to work great.
They look modern and are brighter I think.
Thumbs Up
Post #418527 23rd Apr 2015 11:23pm
