Home > Td5 > Possibly out of luck.......
Fatboy Slim
Wales
Well, now on Td5 number 7, with a combined travelled milage of well in excess of a million miles with no major faults whatsoever on any of them, I may have a case of the dreaded fuel dilution..........oil sample going off tomorrow, let's see what the lab report comes back like Sad
Post #412746 31st Mar 2015 6:31pm
T1G UP
no need for a lab report...if it filling up and it smells of derv then the washers need changing...unless its to late?
Post #412747 31st Mar 2015 6:33pm
Fatboy Slim
Wales
Only a very slight rise and I always work off oil samples. It costs me nothing and I can see the wear rates then and decided if further investigation is required. Its the diesel engineer in me, I can't help it Thumbs Up
Fuel dilution has to be really bad for it to be detected by smell
Post #412748 31st Mar 2015 6:36pm
Fatboy Slim
Wales
Dammit. Fuel dilution detected Evil or Very Mad . Time to hoik the squirters out. Thumbs Up
Post #415920 13th Apr 2015 11:46am
110MGD
2001 Defender 90 Td5 CSW Epsom Green
I had similar on my 2001 90 Td5. With yours being the later 15p engine its less likeley you have a cracked cylinder head. I have a 10p Big Cry
However 2,000 miles *touch wood, and the oil level isnt rising and doesn't smell diesely, so that's a promising sign, that the injector seals have done the trick!!
Mr. Green 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #415952 13th Apr 2015 4:15pm
Fatboy Slim
Wales
I'll get the crack detector out and give it a thorough check as I usually do. I'd strongly recommend sampling your oil if you have any suspicion. I deal with lots of cases of fuel dilution every year on various different types of engine and I can tell you now by the time you can smell it it's bad !!
Post #415954 13th Apr 2015 4:28pm
Fatboy Slim
Wales
Well injector seals done, no cracks found so let's see what the next sample shows Thumbs Up
Post #417214 19th Apr 2015 11:55am
Welkman
Good work and good to know about the longevity of these engines
Post #417376 19th Apr 2015 8:12pm
