![]() | Home > Td5 > Possibly out of luck....... |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
no need for a lab report...if it filling up and it smells of derv then the washers need changing...unless its to late?
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Only a very slight rise and I always work off oil samples. It costs me nothing and I can see the wear rates then and decided if further investigation is required. Its the diesel engineer in me, I can't help it
![]() Fuel dilution has to be really bad for it to be detected by smell |
Dammit. Fuel dilution detected
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 ![]() ![]() |
I had similar on my 2001 90 Td5. With yours being the later 15p engine its less likeley you have a cracked cylinder head. I have a 10p
![]() However 2,000 miles *touch wood, and the oil level isnt rising and doesn't smell diesely, so that's a promising sign, that the injector seals have done the trick!! ![]() 2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
I'll get the crack detector out and give it a thorough check as I usually do. I'd strongly recommend sampling your oil if you have any suspicion. I deal with lots of cases of fuel dilution every year on various different types of engine and I can tell you now by the time you can smell it it's bad !!
Well injector seals done, no cracks found so let's see what the next sample shows
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
Good work and good to know about the longevity of these engines
