povman Member Since: 18 Jun 2010 Location: Victoria Posts: 15 ![]() ![]() |
ti-fat-man, Your spot on with your observation! Before heading into the 1500k/m of corrugated road, we opted for the Kaymar because we already had issues with the weight on the rear door! One of the best mods we have made!!! |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
I've not had much luck with stone chips with the Defender... Got one on the bonnet the day I picked it up with only 19 miles on it! Hopefully Gavin and his speciel resin will be able to sort it, don't fancy a new windscreen that could open up a whole new world of leaks! Will they not replace it under warranty? |
Mine's still in dock
hugh_b Member Since: 15 Sep 2010 Location: Kent Posts: 75 ![]() |
picked mine up from the garage yesterday. It turns out the slight whine from the gearbox was a collapsed bearing which had over heated 5th gear. All sorted now though, much nicer to drive!
Hopefully fit my safari tomorrow! |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
just been to the chinky!
through the puddles of course ![]() |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Started a full stripdown of a 90 V8 to do a full rebuild. Puma 110 SW
90 V8 SOFT TOP |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
Fitted new front axle, whilst at it, new drilled and grooved disc all-round, pads too...Off down to IRBdevelopments monday for some tweeking and fitting of the LED headlights and the VNT Turbo...wished i known about the 6pot calipers he now does before i did mine. Putting Dreams on Drives at JLR Solihull..
Fitted today the "one touch door windows operation" ECU...............
yheaaaaaaa ![]() ![]() ![]() ![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
Come on DG! show us how!
![]() Can something similar be done with door locks when you turn the key? ![]() ............................................................. Earth first. Other planets later |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
This weekend I have fitted, heated wing mirrors, rear led work light and stripped the snorkle bracket down re sprayed and refitted with stainless fixings.
Oh yea, been to work too ![]() |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 ![]() ![]() ![]() |
washed it..........
![]() Def 90td5 CSW xs 2006 |
Spent most of the weekend removing all the rear carpets and trying to find out where the gallons, not joking, of water got in the back when driving home from Yorkshire on Friday. I think the floor panel is the culprit, door seals seem OK. Front was fine, well done Yeovil LR the new foam seal under the windscreen has fixed the front footwell leaks at last
![]() Bob |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Loaded it with Chainsaws, ladders on the roof, trailer and lobbed down aload of fir trees
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Dropped her in at the polacs after Tack and Is Salisbury trip last week, she was a touch dirty
![]() 20 mins and a tenner later and all done....she has a few more scratches as well plus a mangled side step...time for some rock and tree sliders ![]() |
