![]() | Home > Maintenance & Modifications > Urban Truck DRL |
| JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706
Lets see some picks then.
It's the white wire on the ignition |
| CLCraig Member Since: 05 Aug 2014 Location: Somerset Posts: 104
Going to be my weekend project so pictures to follow then. Had a look this evening at the wiring so I have a rough idea.
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
If you use a drl controller you dont need a ign live
how does it say to wire them ? |
Click image to enlarge |
Ok the drl controller they using is just a dimmer for when sidelights on , not voltage sensitive controller
there are lots of different controllers you can get and some use ign live and some just permanent live and earth Does it dim drl,s when sidelights on to turn off drl,s when sidelights on ? |
It dims the DRL's as far as I'm aware. Which is what I would like.
yes i think the dimming are better looking
i still think you need to connect to the white wire. Mine dim on side lights.
| Davie L Member Since: 04 Sep 2014 Location: Glasgow Posts: 95
Hello
Ive just fitted the Quad DRL bumper from Urban Truck, Ive taken the feed straight off the battery through inline fuse to the controllers. There is some wires on the controller that you don't need I think it's a .5 brown and .5 red if I remember right these can be cut off. Connect the whites to the posi on the side light and this will enable the DRL'S to dim once the sides are on. Pic of mine in my album, Don't know how to upload it here though. Davie |
If its non voltage sensing then you need a ign live
The reason i asked as some just use perm live and switch on automatic when engine starts by sensing charge voltage this way they stay on for 30 secs or so after you switch off as a kind of see you home function |
The white is ignition live.
Whites go to the sides for the dimming function 👍
^^^ think he means the white wire on defender is ign live
yes white of drl wiring to sidelight |
| All times are GMT |
