Page 796 of 1392 <123 ... 795796797 ... 139013911392>
Pickles
ericvv wrote:
Washed it, .... well, not myself Laughing , but afterward I towel dried it, cleaned the windows, vacuumed it, treated all door hinges with ACF50 and the tow sockets and antenna with WD-40. And stuck it on the Ctek for a few hours....
This week probably is going to be the last week for the winterwheels/tires, provided that my new ordered General Grabber TR arrive from Continental Tires Germany to my local tire shop.
This truck is 6.5 years old, and never has been waxed or so, only car washes and towel dried. Not bad I think, paint is like a mirror.
And just now this evening I put some tire shine on the winter tires...
Eric
G'Day Eric from Aus.
Mate, I've seen your posts so I know that you know what you're doing, so, I'm not "telling you how to suck eggs"!
However, "Not waxed in 6.5Yrs"??
I reckon that a coat of wax would definitely be a good idea.
I'm no fanatic on this sort of stuff, & "Gracie" is kept in a garage, out of the elements.
But I always give all my cars a waxing once a year,...just takes off a bit of normal road grime/natural "weathering" etc etc. It also puts a bit of a coating/protection on the paint, which is "re-newed" once a year!!
Like I said, I ain't no fanatic, but once a year I reckon, is a good idea?
Regards, Pickles.
Post #414357 6th Apr 2015 11:00pm
ericvv
Afternoon Pickles, I guess a real wax job would not hurt, but sofar just did not see the real need for it yet. Like yours, mine is protected from the elements all year long. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #414374 7th Apr 2015 4:28am
Pickles
G'Day, Yes,it is "afternoon" here!!
Just give the bonnet a go, do half the bonnet, & see if you can detect a difference.
I don't go for any "fancy" ridiculously expensive stuff, just an ordinary polish, & away I go.
I'll normally do just a panel or two at a time, to make sure I do a good job, & get around all the "nooks & crannies", inside & around hinges, badges etc.
Your car's a keeper I know, so I'd be definitely give it a go.
Regards, Pickles.
Post #414375 7th Apr 2015 5:21am
ericvv
Pickles, good idea to do it panel by panel, as opposed to do the entire truck in one go. Probably will give it a try some time this summer, and I probably will start with the bottom side sills where after all this time there are a few marks from getting in the truck. Will use a basic good liquid polish, not going to clay bar it or so.
In any case will wait another 1 or 2 months as first the truck will go back to the north of Switzerland for a full Dinitrol repeat treatment (after it was completely done almost 3 years ago now), and we know those gents there are making the stuff ooze out of all panel gaps up to the top. So will have to regularly clean all that off for some weeks afterward, so polish better come only after that.
Post #414376 7th Apr 2015 5:42am
Pickles
I've never done that claybar stuff, I'm not that keen.
I just like our car to look good not perfect/concourse etc, & just have a good coating of polish on it.
Eric, Don't do the bottom first, start from the top, & work down, & do the wheels last!
I don't use a machine buff either, just the old hand polish! Getting the polish residue out of the badges/hinges/corners etc is a bit of a pain, but the end result is worth it.
Regards, Pickles.
Post #414381 7th Apr 2015 7:12am
excossack
Rearranged the front of the car
Started off like this.
Ended up like this.
Not sure yet if I like it or not. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #414530 7th Apr 2015 7:23pm
More general cleaning done today, body this time and glass etc etc. slight T cut on the odd Mark here or there. A few touch ups tomorrow to do and clay bar everything. Then finally after that a full wash and wax.
Then move on to the inside another day. Laughing
Post #414589 7th Apr 2015 9:26pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Excossack, that is looking far tidier now IMHO Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #414595 7th Apr 2015 9:35pm
excossack
Cheers. I was'nt sure after I did it. In my mind it looked OK, I guess tomorrow when I walk back to it in the works car park I will make up my mind. The other thought is ditch the spot lights and replace with either 1 LED bar or a pair of 72w LED bars and put one under each headlight in the winch bumper.
I was going to put the number plate at the top of the grill but thought it might block airflow to the intercooler as it will be flat against the grill rather than stood off on the A Bar. 1999 Defender TD5 110
Regards
John M0VAZ
Post #414597 7th Apr 2015 9:49pm
Honcho
Ireland
I got to know my inner dash a little better!
Post #414609 7th Apr 2015 10:27pm
Rosco
Excossack, LED's would "de-clutter" the front as you could achieve the same output with much smaller units. Offset the number plate to one side or the other on the bumper? Or don't someone like Mantec make a number plate mount for the plate on the fairlead? 2007 - Stornoway Grey 90 XS SW - Gone
Post #414619 7th Apr 2015 10:49pm
excossack
LEDs would certainly declutter the front & moving the number plate to one side of the bumper would do the trick. At the mo, the number plate is too long to go at the ends, so would need a shorter one making up. 1999 Defender TD5 110
Regards
John M0VAZ
Post #414689 8th Apr 2015 8:22am
Continued cleaning work, clay bar detailing today. Just roof left thought I'd leave that to tomorrow...
Wash and wax after that and finally that's the exterior done after three days.
Then onto the interior at some point.
Post #414854 8th Apr 2015 7:17pm
Venomator
Forgive the ignorance Steve, but what is clay bar detailing... Whistle
Sounds like a recipe for disaster on a shiny truck... Shocked
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #414857 8th Apr 2015 7:25pm
It's completly safe. Thumbs Up I do it about every two years, doesn't need to be that often but it's plenty of work!
Post #414860 8th Apr 2015 7:33pm
