Home > Technical > Dodgy central locking and Alarm ECU probs.
Page 2 of 2 <12
Fifth Horseman
After a little more digging, it seems that the 10as alarm as used in the '96 on Discovery has sill switches on both front doors. I think that this software module for the nanocom was originally written with that in mind and has not been changed for the Defender. BBS may be aware of this known 'feature' - changing it so it is correct for the Defender may introduce problems for other users.
Nanocom was originally developed independently, just for the Discovery (I believe by someone in Italy) and was subsequently bought and further developed by BBS.
Post #413349 2nd Apr 2015 10:28pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Cheers FH, that sounds very likely, I've emailed Christian & Adrian @ bbs were helping me with the pin-8 error, we originally thought the unit was at fault and we were discussing sending the unit back but seeing as I found fault with the car I'm glad I didn't send it, I've asked the question about the sill switches so now awaiting their reply, but your theory sounds very plausible. Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #413369 2nd Apr 2015 11:44pm
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Pardon my ignorance but where are these sill switches, is it the ones that turn off/on the courtesy lights.
I have had my alarms system act up over the last few days and am trying to fix it.
I don't have a nanocom just working through with visual inspections and multimeter.
If I lock the car with the plip, the locks engage, almost immediately disengage and the alarm goes off.
Going to try it with the key, and see what happens, at least it will be quieter.
Tommy Tommy
110 XS TDCi
Post #414123 6th Apr 2015 8:33am
Fifth Horseman
The sill switch is attached to the drivers side door lock, the others are the interior light switches on all other doors, plus the bonnet switch. Check the switch wiring for chafing and shorting against the bodywork. Sounding twice then unlocking means the alarm thinks one of the doors is still open.
Does your interior light work correctly, if so then check the bonnet switch.
Also check the alarm connectors for corrosion, if your vehicle has had a water leak around the windscreen the alarm is in a vulnerable place - its not unknown for water to affect the alarm unit itself.
Post #414125 6th Apr 2015 8:43am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Tommy
The door switches are located halfway up the pillar at the front of the door (same side as the hinges) they're held in place by a single screw.
Nick Mc has just done this job, here's his thread http://www.defender2.net/forum/topic36144.html
John 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #414126 6th Apr 2015 8:44am
Page 2 of 2 <12
