Home > Puma (Tdci) > Rusty bumpers
Cadence
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Rusty bumpers
Hi, I'm expecting my first 110 next month.
I considered buying nearly new but there was precious little difference in price, so went for new.
One dealer offered me a 2014 model with loads of option/accessories - lovely vehicle but the price was "Whatever the list price was for the car and all options when we first registered it" - Or zero depreciation and you'll be the second owner.
Bought new for less.
When looking at 12 month old Defenders, many had a surprising amount of rust of the front and rear black bumpers. They didn't look like they'd seen any off road usage but would have had one winter of salty roads to contend with.
Is this just the result of wafer thin paint or is there anything to be done to slow the onset of the orange peril?
I plan to have the whole vehicle rust proofed from new so there may be action that could be taken then
Cheers for any advice
Post #413965 5th Apr 2015 2:34pm
In my experience the bumpers are rusty before they leave the factory.
It will certainly help to under seal them at the same time as getting the chassis done.
Post #413969 5th Apr 2015 2:48pm
mk1collector
I got a new bumper for my older defender and painted the front then dinitrolled the back and I've not had any rust in the last two years. It's just the cheap paint finish from Landrover that causes them to rust so fast.
Post #413976 5th Apr 2015 3:14pm
X4SKP
Hello Cadence
and so it begins...you are right (in my opinion) Land Rover really should do better, and may do better with the replacement Defender at sending it out the door with a tough, fit-for-purpose all over protection, especially for the metal bits underneath.
Some look to have only been shown the spray gun... with the accompanying comment that 'this is reserved your
more expensive stable mates'. Front Bumper, rear Cross Member, All Running Gear will often show early signs of deterioration.
Your under body corrosion prevention exercise (if done correctly) will address most of this but the outer coating of paint on the rear cross member and front bumper may need to be tackled at some point early in life. Get a good quality paint and apply it properly or take it to a body shop who can apply a two pack paint to get a really tough finish.
I did all of the above to mine with 10K on the clock. The Front Bumper should also be taken off as part of the anti-corrosion treatment and the inner surfaces (including the hidden areas) should be protected too... this is mine after the Dinitrol treatment.
(my front bumper has a vinyl outer wrap which I thought would be rubbish but I have been surprised how good it's been)
Good Luck...
 SKIP
Post #413978 5th Apr 2015 3:25pm
Cadence
Many thanks for the valuable feedback.
BTW when you say 'Vinyl Wrap' do you mean clear paint protection film like 3M Venture Shield or Armourfend?
Post #413983 5th Apr 2015 3:43pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
One of my favourite mods is my DRL bumper from FCX it's much thicker than the standard wafer thin bumper. well worth the money in my opinion!
Post #413985 5th Apr 2015 3:53pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Or… do nothing.
It’ll be a good few years before any rusted bodywork will become dangerous or an MOT failure, by which time your truck will be worth whatever it’s worth. Yes, Dinitrol, AC-50, bling it up all you want, and it may (just may) delay the re-chassis by a couple of years or convince a punter to pay a few quid more than Glass’s Guide.
But by that time you’ll have had your use out of it, the repairs and unreliability will in any case be taking its toll, and you’ll be only too glad to get rid of it for something new.
If your time is as precious as mine - take bumpers off and paint them? Yeah, I should think so - for as long as it works, looks good and makes others envious, use and abuse it, hump it and dump it, spend as little money on it as you can get away with, and then let somebody else take over the headaches.
Peter (umpteenth car, third wife)
Post #413989 5th Apr 2015 4:03pm
X4SKP
Hi Cadence
Close... mine has a few areas with 3M Carbon Fibre Vinyl applied,
Silver Graphite Spec' which is very (very) similar to the Stornoway Grey of mine
and so overall looks 'colour coded' to match, all cosmetic I know, but ok I think,
(at first glance you almost don't see it).
Front Bumper, Steering Guard, Wheel Arches, Bonnet and Roof... 3M Vinyl
 SKIP
Post #413990 5th Apr 2015 4:10pm
Cadence
Looks great - I Hope mine looks that good.
I much prefer to treat my vehicles well from the outset rather than the 'let them rust and flog it' approach that was also suggested.
Post #413993 5th Apr 2015 4:48pm
X4SKP
Hi again Cadence
Totally agree and it's a Defender after all... Exclamation
Use it the way you want to, but a bit of front end protection and the occasional bit of TLC along the way
coupled with a strong resale value and you have a fairly sound investment... Thumbs Up
After a Series III, I looked at a nearly new 300tdi Vs a new one and decided to go for new as there
was so little in it. Had it for 19 years without issue and sold it to get the Puma, in terms of depreciation
the 300tdi cost Ł375 / PA, unless you have a classic car that appreciates in value, that's not bad.
The Puma is staying around also, but here's its predecessor...
Enjoy yours SKIP
Post #414034 5th Apr 2015 8:39pm
dailysleaze
Supposedly this bumper should resist corrosion more than a standard one:
http://www.johncraddockltd.co.uk/land-rove...with-.html
Post #414045 5th Apr 2015 9:29pm
Cadence
Thanks again for all the feedback - undoubtably worrying more than I need to. Probably the hefty price that gives me the sweats Wink
Post #414554 7th Apr 2015 8:13pm
AndyS
I wouldn't bother trying to weather proof the original bumper, they're very soft and bend on the slightest of nudges which will crumple your wing. Better to ditch it and get a like-original bumper made of something more substantial (5mm steel I think is what I got) and have a little confidence that your bumper will actually be able to bump something and not bend.
Post #414564 7th Apr 2015 8:35pm
Cadence
Sound idea - Thanks
Post #414565 7th Apr 2015 8:36pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Just let the bumper do its thing...
The dealer's know they replace them at 3 years old just before the warranty runs out..
along with headlamp rings, rusty mirror arms and any rusty door bolts.
I just build up a list and then hand it over..No issues at all
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #414571 7th Apr 2015 8:47pm
