Home > Tdi > Newbie Question About Sluggish Performance
chrispy
Wales 1987 Defender 90 300 Tdi CSW Keswick Green
Is there a post or faq here about how to get some more power out of our 300Tdi? I've searched high and low but anything i've found is very technical and I just need something to explain the options in simple English to me even though it will be going to a garage for the work. There is very little guts in our 90 and living in the mountainous land of Wales it takes forever driving home from work 3 miles away. It's a lovely smooth ride (which quite surprised me) but long a very laborious pmsl. The engine starts on the button every time and is very reliable, if I could just solve this 'Driving Miss Daisy' mode it's in we'd be happy bunnies.
Thanks in advance.
Post #413950 5th Apr 2015 1:58pm
gilarion
The 300TDi engine should not give you any problems on hills, so there must be something wrong, have you checked all the pipes attached to your turbo for leaks and firm attachment, sometimes a leaking turbo pipe can drastically cut down engine performance.
Other than fitting a full sized intercooler the only other option for more power is proper timing, setting tappets correctly or tweaking the fuel pump. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #413961 5th Apr 2015 2:20pm
chrispy
Thanks for that my friend. There was a whopping big intercooler already installed in it when we bought it a month ago. I'll check the pipes and see what's happening, many thanks.
Post #413972 5th Apr 2015 2:54pm
dailysleaze
I had a turbo pipe split once. On hills I just had to keep changing down the gears until I crawled over the top in second
Post #414044 5th Apr 2015 9:26pm
chrispy
I'll check it out tomorrow, thanks Thumbs Up
Post #414046 5th Apr 2015 9:31pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
did you sort it chrispy
Post #414054 5th Apr 2015 9:41pm
chrispy
No mate, tomorrow when it's daylight. Been choka block all day today sadly. It's a recon turbo on there (only bought about 6 months ago with all new pipes) so i'm thinking if it's not a broken pipe (which I doubt) maybe something wasn't put on right when it was put back on. I'll probably end up taking photos to show you guys as i'm new to this working on your own car gig and it's quite exciting the thought of being able to repair it myself Thumbs Up
Post #414078 5th Apr 2015 10:20pm
chrispy
All pipes are fine and not cracked or split. In fact they're all new.
Post #414221 6th Apr 2015 5:40pm
K9F
Afternoon Chrispy.....
Try this for a kick up the pants....... Thumbs Up Laughing
All you need to know....with pictures: Thumbs Up
http://www.landyzone.co.uk/lz/f8/sluggish-...46991.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #414224 6th Apr 2015 5:48pm
chrispy
Many thanks my friend.
Post #414226 6th Apr 2015 5:52pm
