![]() | Home > Technical > Q421- Oil Pump Failure **JLR RECALL** |
After some weeks of speculation, the recall for Defender 2.2 Oil Pumps is now here. (This has only happened within the last 3 hours I might add!!)
Vin Range: LD405037 - LD443988 As follows:
This recall consists of: Replace the oil pump, oil sump, oil pickup pipe, oil pump outlet pipe, oil filter & refill with engine oil. Regards Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Anybody had this from JLR yet? NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
My 2.2 was registered in Feb 2012. I will be calling up the dealer for sure.... 1998 Tdi 90 SW,
2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
Just checked Topix for mine and the recall is registered for it.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Bob - do you need a paid subscription to see that on Topix? I had a look earlier in the free section but couldn't see anything.
If you have registered as a private owner you can see all the recalls etc for your vin number but a lot of the further details are paid subscription only.
You can't actually read the recall notice but you can see if it is applicable to your vehicle. If you can't register or are having problems then PM me your full vin and I will check for you. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Bob - thanks, I'll have a go at registering on Topix later. From the VIN range quoted above, it looks like mine is included.
Being a cheapskate, as my service is also due, I'm hoping that the cost of the oil change & filter will go on the warranty bill and I'll pay only for the other items ![]() |
Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 ![]() ![]() ![]() |
I've just checked TOPIx and BamBam is registered for this recall
![]() As luck would have it, he's already been booked into Harwoods for the second year service on Thursday next week... |
The white 90 is in that range too and strangely enough when I started it on Wednesday a message flashed up on the dash saying oil service. I've never seen that before
![]() They will be getting a ring tomorrow. Regards Barbara |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2074 ![]() ![]() |
Looks like I'm in too
![]() Don't have the LD before the numbers but my numbers fall into this group |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
Don't panic that's a normal message and just means the defender needs an oil change ![]() |
Steve E - you must have, it's just that they will be earlier in VIN number - otherwise you don't have a defender!
Yours must start, something like this SALLDHMP7DA - followed by 6 digits. where: SAL = Land Rover (UK) LD = Defender H = 110 inch M = 5 door station wagon P = 2.2 Euro spec EU5 engine 7 = RHD 6 speed manual transmission D = 2013 model spec A = Solihull plant Last edited by Supacat on 3rd Apr 2015 4:50pm. Edited 1 time in total |
Would appear mines on the list, numbers match, will be visiting the Dealers at the first opportunity. NormanD WE191
but has it been triggered by time (12 months since last service) or oil dilution? |
