Home > My Defender > My 90 Td5 XSish CSW
NickMc
My 90 Td5 XSish CSW
Here's my Td5 90 XS spec CSW i built this onto a Galvanised chassis about 4 or 5 years ago and after regretting ever selling it i bought it back at the end of last week.
All ready started scheming what mods im going to do and have fixed a few annoyances already. Unfortunatley i don't think the last owner ever washed it Rolling Eyes and it needs a trip to the bodyshop to get a few front panels re-done. A set of vent flap seals and new front door seals. A set of lights on the roof rack and a few subtle amber strobes and something to store all my gear in which is a real pain in these bulkheadless CSWs. The mud flap brackets have gone rusty and I've a new set arriving tomorrow too.
I need to take the 10 AS box out and change it into a 280 spec box asap as the central locking not working is already annoying me no end, i have the relay and bits sitting here i i can find the time to get the soldering iron out.
I built this how i wanted it at the time XS spec without the aircon crap.
Mammouth chequer plate wing top and sills
Alarm Tracker
Genuine Rear tow step (which needs to go as i tow a fair bit and it's not up to the job)
Genuine Mats and carpet inside.
Rear tie down eyes
Genuine Tomb raider side steps which are off to get the silver chequer redone in black
ZU Alloys
Genuine Expedition Roof Rack
General Grabber ATs
Heated seats
Heated front screen which needs wired in
Electric windows
Custom IRB developments Re-map which is still as good as i remember Thumbs Up
Few mods I have planned:
280 AS box
Wolf Wheels
More work and spot lights
Amber strobes
Drop hitch
Rear USB ports
Rear storage
Upgrade the audio
Bigger intercooler
Interior Labcraft lights
Heated mirrors
Reversing/hitching camera
LED head lights
Mud stuff overhead console
Mud stuff front dirt-defenders.
Post #412230 30th Mar 2015 12:35am
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Looks good, nice spec list.
Is that your 2 Door RRC too?
Post #412430 30th Mar 2015 8:24pm
NickMc
No it's not mine rebuilding it for a customer. It's actually not a 2-Door, but one of the first of the 4 Doors
Post #412491 30th Mar 2015 9:47pm
NickMc
Changed the 270 spec box into a 280 spec box so the central locking will work. Had a few of these about so did two this evening.
270 10 AS immobiliser box
Split the box in half to get at the circuit board. The easiest way is to slip a screw driver in this way round and push the tabs down, if you try it the other way round you'll damage the locators.
Inside the 270 box
Inside a 280 box notice the extra rectangular relay and Blue MOV
Here is where the relay goes next to the other relay, you'll need to desolder the 8 joints to affix the relay.
And this is where you'll add the MOV to protect the Relay you just need to place the MOV on top and heat up the exsiting solder and maybe add a bit more.
MOV in Place
Relay in place and soldering done
Two boxes side by side all I need to do is pop the lid on and program it with the autologic fingers crossed.
Post #412565 31st Mar 2015 1:03am
NickMc
Pleased to say it works perfectly, best mod I've ever done for �8 and a bit of time with the soldering iron.
Post #412729 31st Mar 2015 5:25pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Nick Glad to see the 90 found its way home, looks as good as ever....if your looking for a set of wolf rims I may know of a set near you....text me if you need them.
I too bought a TD5 90 at the weekend....hell of a lot rougher than yours tho .
Nigel
Post #412779 31st Mar 2015 8:02pm
NickMc
Nothing a bit of spit and polish can't fix.
Already picked up a set of 5 genuine ones the day I bought it, thanks though.
Post #412856 31st Mar 2015 11:27pm
NickMc
Got my wolfs back from the powder coaters today.
Post #413553 3rd Apr 2015 6:32pm
NickMc
Changed the corroded door switches today to get rid of the annoying intermittent faults cheap and cheerful and well worth the ten minutes it took.
Post #413808 4th Apr 2015 7:41pm
NickMc
Fitted two new steering shaft UJ's to replace the bottom one which had some play and was knocking over the bumps which I couldn't take any longer Confused
Also fitted two new rear mudflap brackets today, I'll send the originals off to the galvanisers and powder coaters with some stainless cap head set screws.
Ordered some Spot Lights, aux fuse box and a jump start kit, heated mirror, 12v sockets and a few other goodies too.
Post #414108 6th Apr 2015 1:57am
Anderzander
Doing some great work here Nick ! And what a lightbulb moment for me with changing the door switches ..... Can't beleive I never thought of how simple it would be to swap mine out.
Post #414122 6th Apr 2015 8:26am
Fifth Horseman
On thing to consider when upgrading the 10as unit for central locking is that you don't get the safety unlock in the event of an accident - from L/R Topix
Quote:
The anti-theft system module also incorporates an internal inertia switch. In the event of an impact of sufficient severity to trigger the inertia switch when the ignition switch is in position II, the anti-theft system module will unlock all doors and operate the hazard flashers. The anti-theft system module will remain in this mode of operation for 2 minutes. To de-activate the hazard flashers and restore the anti-theft system module to its normal mode of operation, the ignition switch should be turned to position 0 and back to position II after the 2 minute period has expired.
The inertia switch is the block on the top left of the picture of the 280 alarm/locking unit.
Post #414127 6th Apr 2015 8:55am
NickMc
I guess if i really wanted i could fit one, but most boxes have it disabled.
Post #414921 8th Apr 2015 11:23pm
NickMc
Colour matched my steering wheel badge and gear/transfer box knobs Cool
Combo of brush, cocktail sticks, cotton buds and some thinners to wipe off the excess when it is nearly dried.
PIMPIN' Laughing
Post #415104 9th Apr 2015 9:06pm
NickMc
Got my LED spot lights and Wolf wheels fitted order from Mud has been sitting here for a while with heated mirrors, USB and 12v sockets and interior lights if I could get time to fit them.
Post #416235 14th Apr 2015 8:25pm
