![]() | Home > My Defender > My 90 Td5 XSish CSW |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
Looks good, nice spec list.
Is that your 2 Door RRC too? |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
No it's not mine rebuilding it for a customer. It's actually not a 2-Door, but one of the first of the 4 Doors
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Changed the 270 spec box into a 280 spec box so the central locking will work. Had a few of these about so did two this evening.
270 10 AS immobiliser box ![]() Click image to enlarge Split the box in half to get at the circuit board. The easiest way is to slip a screw driver in this way round and push the tabs down, if you try it the other way round you'll damage the locators. ![]() Click image to enlarge Inside the 270 box ![]() Click image to enlarge Inside a 280 box notice the extra rectangular relay and Blue MOV ![]() Click image to enlarge Here is where the relay goes next to the other relay, you'll need to desolder the 8 joints to affix the relay. ![]() Click image to enlarge And this is where you'll add the MOV to protect the Relay you just need to place the MOV on top and heat up the exsiting solder and maybe add a bit more. ![]() Click image to enlarge MOV in Place ![]() Click image to enlarge Relay in place and soldering done ![]() Click image to enlarge Two boxes side by side all I need to do is pop the lid on and program it with the autologic fingers crossed. ![]() Click image to enlarge |
Pleased to say it works perfectly, best mod I've ever done for �8 and a bit of time with the soldering iron.
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
Nick Glad to see the 90 found its way home, looks as good as ever....if your looking for a set of wolf rims I may know of a set near you....text me if you need them.
I too bought a TD5 90 at the weekend....hell of a lot rougher than yours tho . Nigel |
Nothing a bit of spit and polish can't fix.
Already picked up a set of 5 genuine ones the day I bought it, thanks though. |
Got my wolfs back from the powder coaters today.
Changed the corroded door switches today to get rid of the annoying intermittent faults cheap and cheerful and well worth the ten minutes it took.
Fitted two new steering shaft UJ's to replace the bottom one which had some play and was knocking over the bumps which I couldn't take any longer
![]() Also fitted two new rear mudflap brackets today, I'll send the originals off to the galvanisers and powder coaters with some stainless cap head set screws. Ordered some Spot Lights, aux fuse box and a jump start kit, heated mirror, 12v sockets and a few other goodies too. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Doing some great work here Nick ! And what a lightbulb moment for me with changing the door switches ..... Can't beleive I never thought of how simple it would be to swap mine out.
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
On thing to consider when upgrading the 10as unit for central locking is that you don't get the safety unlock in the event of an accident - from L/R Topix
The inertia switch is the block on the top left of the picture of the 280 alarm/locking unit. |
I guess if i really wanted i could fit one, but most boxes have it disabled.
Colour matched my steering wheel badge and gear/transfer box knobs
![]() Combo of brush, cocktail sticks, cotton buds and some thinners to wipe off the excess when it is nearly dried. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge PIMPIN' ![]() |
Got my LED spot lights and Wolf wheels fitted order from Mud has been sitting here for a while with heated mirrors, USB and 12v sockets and interior lights if I could get time to fit them.
