![]() | Home > Puma (Tdci) > Puma 110 rear hi line brake light. |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
You can run a wire from the live feed inside the door round the rubber seal and into the brake lamp and no one will ever know. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
As mentioned above, repair.
The earth uses the same system as the rear heated screen. Simply run that wire dude. Steelers ey !? |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Even the 'Landyglass' replacement wire runs up the rubber......You can get a replacement LED light off them too!
"The slim line led brake light and wires runs inside rubber available at extra cost in online shop" http://www.vehicleglazingspecialists.com/-90-products.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568
I thought someone here would know! thanks
| AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242
The stealer in Perth changed my window for exactly the same reason. Probably takes too long to change the globe or rewire I suppose.
Bloody Land Rovers..... AlanH. PS. Why have the Cook and I had 3 of the damn things...plus a Disco!!!! |
| All times are GMT |
