Home > Puma (Tdci) > Puma 110 rear hi line brake light.
pannawonica
Australia
Well I did not know when the high line brake light fails they have too replace the whole glass! Big Cry That was according too the stealer, unless you know different? Very Happy
Post #411311 27th Mar 2015 3:25am
RED-DOT
You can run a wire from the live feed inside the door round the rubber seal and into the brake lamp and no one will ever know. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #411325 27th Mar 2015 7:55am
theorangebandit
As mentioned above, repair.
The earth uses the same system as the rear heated screen. Simply run that wire dude. Steelers ey !?
Post #411330 27th Mar 2015 8:34am
K9F
Even the 'Landyglass' replacement wire runs up the rubber......You can get a replacement LED light off them too! Thumbs Up
"The slim line led brake light and wires runs inside rubber
available at extra cost in online shop"
http://www.vehicleglazingspecialists.com/-90-products.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #411347 27th Mar 2015 9:45am
pannawonica
Australia
I thought someone here would know! thanks Very Happy Being that I was on this occasion winding the lease up on the Puma I let them fit the window. I asked them about rewiring and they said, " If it was that easy they would be doing it." Seems dealers the world over are exactly the same! Rolling with laughter Paid out of lease and now Very Happy warranty, freedom at last.
Post #411599 28th Mar 2015 4:43am
AlanH
Australia
The stealer in Perth changed my window for exactly the same reason. Probably takes too long to change the globe or rewire I suppose.
Bloody Land Rovers..... Laughing
AlanH.
PS. Why have the Cook and I had 3 of the damn things...plus a Disco!!!!
Post #412275 30th Mar 2015 11:25am
