Home > Maintenance & Modifications > The definitive wheel and tyre thread..HOW THEY LOOK
Page 22 of 42 <123 ... 212223 ... 404142>
Tidy. Thumbs Up
How are they on the road? QRZ 2e0vpf
Post #411561 27th Mar 2015 11:17pm
Windowlicker
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Twisted 16's , zero offset , with 265/75/16 Duratracs fitted. Smile
 "Procrastination is the thief of time"
Post #411563 27th Mar 2015 11:22pm
Jim_Bean
Like running up a tarmac hill in rugby boots!
Surprisingly quiet but definitely have an effect on acceleration (and probably fuel).
Need to turn in the steering stops tomorrow as they just catch at the moment.
Still amazed at how smooth your TD5 transmission is compared to my Puma. You'll have to take mine for a spin Steve Thumbs Up
Post #411564 27th Mar 2015 11:24pm
( Cool windowlicker)
Laughing rugby boots!
I thought they'd be a hell of a lot more noisier, compared to the oe tyres.
As for 'quiet td5' I bet your back door doesn't rattle. I need a spare wheel carrier. QRZ 2e0vpf
Post #411570 27th Mar 2015 11:35pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Windowlicker - do the Twisted 16" with 265 Duratrac's stand proud of the arches? I notice on there site that the 16's only come with an ET0
Post #411571 27th Mar 2015 11:39pm
Windowlicker
Looked at as a true side on profile, the sidewall tread stands proud of the arches.
The actual "flat" road contact patch finishes bang on the edge of the arch spat.
I guess the ideal wold have been to stick to 235 Duratracs which would have been perfect.
I have recently modified the Mudflaps front and rear, moving them outboard by around 2" , so they are now effectively similar in offset to the outer edge of the tread.
There has been a bit of a form over function end result Embarassed and I guess the narrower option would have been more sensible Whistle
Either way, the masses of extra lock available with the twisted wheels makes a huge difference to low speed manoeuvrability Thumbs Up "Procrastination is the thief of time"
Post #411577 28th Mar 2015 12:03am
Rugbyball
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Overfinch alloys
Hi
Has anyone bought or used the 18" Overfinch Apollo alloys (below)?
Any views?
Generally what is the impact in ride quality (on the road, sorry!! Very Happy ) changing from standard Boosts/235 Contis to an 18" wheel with 265s?
 2015 Overfinch Defender XS 90
1998 50th Anniversary V8
1989 90 CSW
Many Discoveries...
Post #412828 31st Mar 2015 10:09pm
Lambley
Post #412831 31st Mar 2015 10:15pm
Rugbyball
Thanks Lambley, had a look. Pretty good aren't they!
I wonder what the change in ride quality is like between 18 and 16.... 2015 Overfinch Defender XS 90
1989 90 CSW
Many Discoveries...
Post #412838 31st Mar 2015 10:28pm
Not mine but these certainly fill the arches:
Post #415362 11th Apr 2015 11:49am
Jim_Bean
Is there any noticeable difference between a 265/75 R16 and a 265/70 R16?
I realise the profile will be a bit lower but is it enough to make a real difference in the handling?
Thanks Thumbs Up
Post #415925 13th Apr 2015 12:16pm
Lambley
I don't think you'd notice the difference tbh but they'd be nearly an inch smaller diameter, I'd stick to 75's because there's also more choice of tyres. It also depends on the type of tyre and sidewall. If you want a stiffer ride then swap to 18's maybe?
Have you sold or swapped your wheels/tyres now then? What are you replacing them with?
Post #415930 13th Apr 2015 12:37pm
ericvv
Post #415931 13th Apr 2015 12:48pm
Crispin
Does anyone know where I can get some 285/75R16 Duratracs, they're like hen's teeth to find. Also i'd like to raise the front of my 110 by an inch or so to match the clearance on the rear. Any ideas? Oh, My current rather boring setup of Conti A/Ts and Sawtooth wheels.
Post #415965 13th Apr 2015 6:00pm
110lab
United Kingdom 2006 Defender 110 Td5 CSW Bonatti Grey
Just got myself a set of these Satin 17" Manta's...
Saving up for a a set of 265's BFG's TA... hopefully not too long a wait!
Post #415967 13th Apr 2015 6:01pm
