![]() | Home > Puma (Tdci) > Ticking Noise |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
So ours is the same age as Andys. It's done around 8,000 miles less. Hubby is ringing the garage at 9 to see if he can pop it into them this afternoon. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
CLCraig Member Since: 05 Aug 2014 Location: Somerset Posts: 104 ![]() ![]() ![]() |
Let us know what it ends up being. Hope it's nothing serious for you
Well it appears to be a flexible joint on the exhaust that is loose. It's going in on Wednesday afternoon for new pads, diff seal and this so hopefully all will be back to normal. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
Think I know the section, question is, why?
Someone knows why it is loose all of a sudden. ![]() |
by listenning to recording , i would not have said that was a exhaust blow , but always hard to tell like that the flexi is in front pipe , along with cat might be worth checking price before you give go ahead , as might be worth going for second hand one |
So she's been in the workshop today.
Has new brakes all around and the rear diff seal has been sorted. Total cost came to just under £250 inc VAT. With reference to the ticking noise, once on the ramp they have concluded there is nothing externally obvious. It appears that on closer inspection it's coming from the Bell Housing/Clutch and that it is the springs chattering. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
