Home > Puma (Tdci) > Ticking Noise
Page 2 of 3 <123>
Live diagnostic may prove useful, perhaps an injector?
Post #409930 22nd Mar 2015 5:34pm
munch90
I was thinking the same maybe injector , but normally there are other things as well like hard to start , smokng , misfire etc
take it everything seems fine other wise
Post #409931 22nd Mar 2015 5:37pm
CatherineF
It does run very well still doing 29 mpg pulls like a train etc. I'm 99 percent certain it's coming from underneath the engine and around the bulkhead area. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #409933 22nd Mar 2015 5:42pm
Would the glow plugs have any effect munch?
I was just thinking if it was an injector, doesn't that show up as live info on some diagnostics as the pressure.
In other words you can determine with out inspecting if the pressure is too high or too low on an injector individually.
Post #409935 22nd Mar 2015 5:42pm
munch90
cant get a individual pressure difference to injectors as its common rail
bad spray pattern maybe on injector
no glow plug wouldn't do it , also there on n/s under inlet manifold
dianostics check wouldn't be my first thing , but wouldn't hurt to check
if its on one cyl then really you would need to find out which cyl by going though one by one , not something I would say how to do on a forum , as high pressure diesel is not something to play with as a injector will inject diesel though your skin if you had your finger over the end !
Post #409936 22nd Mar 2015 5:54pm
CatherineF
Ok so how quickly do we think this needs to go into the workshop? Are we talking tomorrow morning or would it be fine to do its usual 60 mile trip and then try and pop it in tomorrow pm? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #409937 22nd Mar 2015 5:57pm
munch90
fine to do a 60m trip ? no one could say 100%
get it checked ? yes
take it gentle ? yes
it maybe nothing and it goes away , like I said before could be something silly like a air bubble in a hydraulic tappet and might clear on its own , possible after oil change ,but would have expected it to have cleared by now
Post #409938 22nd Mar 2015 6:00pm
CLCraig
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
Have you checked the oil level yourself? Sounds like a dry tappet to me but hard to say via a video
Post #409941 22nd Mar 2015 6:19pm
CatherineF
Yes oil level checked and all is good there. The service was done at 39,598 on the 12th March. It's now done 39,952 and today was the 1st time I've driven it so I've no idea how long it's been like that as I last drove it before it went for service. The only observations made were that it needed a new rear main diff seal and new pads all around which I'd pretty much expected. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #409945 22nd Mar 2015 6:28pm
pob1968
Mine came back from the dealer after its service with a missing engine cover bolt and a nut off the ecu. 110 Hardtop
Post #409952 22nd Mar 2015 6:44pm
YOLO110
Australia
Re: Ticking Noise
CatherineF wrote:
Fired her up today and it's developed a metallic sounding ticking noise, which you can hear from inside the truck as well as outside in addition to the normal Puma engine sounds.
I think it's coming from the underside and it doesn't appear to change with engine speed. It's no better or worse when warm/cold. When moving you can't hear it, it's only audible at idle/low engine speeds. At one point after a blast down an A Road I thought it had gone but it hasn't.
Any thoughts? I'm sorry I can't be any more specific.
I would take it back to the dealer and get them to sort it!
To me, it sounds like a tappet... did you have the oil changed? If the engine has oil hydraulic tappets, one of them could have bled down which would explain that noise. If this is the reason, it should self cure after about 15 mins of normal driving.... Rolling Eyes YOLO... You Only Live Once...
Post #410055 22nd Mar 2015 11:01pm
CatherineF
Well it's done around 300 miles since it was serviced.
I also must stress that with the bonnet open this noise doesn't appear to be coming from the top/front of the engine.
It really only audible from underneath. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #410061 22nd Mar 2015 11:07pm
Farmer_Harry
Mine does exactly the same, I haven't had chance to look for the cause yet, so I'll keep an eye on this thread.
Post #410063 22nd Mar 2015 11:12pm
CatherineF
How old and how many miles Harry? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #410068 22nd Mar 2015 11:19pm
Farmer_Harry
60 plate and on about 48,000
Post #410074 22nd Mar 2015 11:57pm
Page 2 of 3 <123>
