![]() | Home > Maintenance & Modifications > Spare wheel lock |
gklau Member Since: 17 Jan 2015 Location: Leicester Posts: 35 ![]() ![]() ![]() |
Hi,
May be useful spare wheel lock for someone with boost alloys? eBay Item No. 151611401996 |
Now that is a neat and tidy solution to an age old issue 'How to lock the spare?' I manufactured a 3mm stainless plate to cover the nuts. Downside being it takes about 20 minutes with the correct tools to remove the spare. It is however another 'layer.'
![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
My plan is to put a horizontal threaded pole through the middle, bolt in a bracket for a shovel and a padlock to finish.
Doubles as spare wheel lock as well then. But first need to fit a spare wheel carrier... |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
Nice and simple piece of kit. Will probably buy one as the bike lock metal rope I currently wrap around the wheel and carrier looks a mess.
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
I've got a pretty good idea which is lockable with a padlock. All stainless steel and nearly universal fit.
If there is enough interest here we can produce it. WANTED: SII or SIII in max 1.5k |
It will be a "no drilling required" solution. WANTED:
Yes!
Would be interested. Not keen on drilling through my spare wheel carrier. Can you make one in black to match my wheel? |
My intention would be the usual stainless or black versions, so black is no problem. WANTED:
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
I would be interested as well
![]() http://www.youtube.com/user/conwy1 |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1319 ![]() ![]() |
Interested if it will secure Sawtooths?
Clemmo |
it will secure any wheel, steel or alloy WANTED:
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
?? and 18" Bowlers
![]() Main Brian James Trailer Dealer for South West UK |
Any wheel as long it has a hole in the middle and a pattern of 5x165.1 WANTED:
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
I'd like 2 please
