Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 17 of 81 <123 ... 161718 ... 798081>
Tiger
Watching with interest ( as ever )
Did you go for the Britpart kit?
Post #409322 20th Mar 2015 6:52pm
mk1collector
Yey someone does read my ramblings Rolling with laughter I just went for take off parts from ebay so totally standard bits. Just had to run an errand and can honestly say even with just the front there's a lot less roll around corners. I think I'm putting new shocks and slightly lowered springs on this year too so im hoping for a good on road improvement overall.
Ray Thumbs Up
Post #409351 20th Mar 2015 8:38pm
mk1collector
Managed to get a couple of bits painted up so when the weather is a bit warmer and nicer I can get them fitted and it should look tidier Mr. Green
Sorry for the rubbish pic.
Ray Thumbs Up
Post #410262 23rd Mar 2015 7:28pm
mk1collector
All the bits for a big job finally collected so should be going on in a couple of weeks Cool started with the crank pully starting to go but ended up deciding to do everything while the front was off so it's getting pully, new pully bolt, aux belt, crank seal, both idlers, tensioner, water pump, power steering pump, radiator, intercooler and the silicone hoses that have finally turned up correct after 6 weeks Big Cry also in the pics to do are the rear anti roll bar, new sills and the rest of the stainless bolt kit! So a busy time ahead but hopefully everything should be running great when it's finished : Mr. Green
I'm hoping britpart can't mess up a radiator as everything else is oem.
Thanks for looking
Ray Thumbs Up
Post #410568 24th Mar 2015 6:03pm
mk1collector
New springs have arrived Mr. Green -2.5 rear and -1.5 front by extreme. Another ebay bargain having only been used for around 100 miles before the chap sold his 110 so I got them at 1/4 of the original price Cool I just need some spare time and good weather to put all these bits on Big Cry
Ray Thumbs Up
Post #412960 1st Apr 2015 2:29pm
mk1collector
Started the lowering job and got the backs in already. Just having a rest before tackling the fronts Mr. Green
Old and new
One in
And the back done
Cheers for looking
Ray Thumbs Up
Post #413756 4th Apr 2015 1:55pm
g-mack
doesnt look right mate! take them out send them to me and i will dispose of them for you! Rolling with laughter My 109 thread
my youtube channel
Post #413757 4th Apr 2015 1:57pm
mk1collector
Fair enough, give me half an hour Rolling with laughter
Post #413758 4th Apr 2015 1:58pm
g-mack
on serious note, i wonder if you could still fit 255 85 16s under there now My 109 thread
my youtube channel
Post #413759 4th Apr 2015 1:58pm
mk1collector
Not sure, what's the difference in wall hight? I think I'm going for the 18" sawtooths that lri solutions do next year when I've recovered from the expense of all these new bits Big Cry so I need to check out what tyre sizes are best for a bigger wheel.
Ray
Post #413760 4th Apr 2015 2:03pm
g-mack
255s have 33inch diameter so about an inch more than 265s
i would like to lower mine to make easier access for dogs and swmbo, but put 255s on to lift diffs a little. My 109 thread
my youtube channel
Post #413766 4th Apr 2015 2:31pm
mk1collector
I've got 235's on mine and it had 4 1/4 inch gap from tyre to arch at the front and 5 1/2 gap at the back and although I've not driven it to settle the springs yet it sits level at 3 1/2 inch gap all round now. My old springs had done 110000 miles though so we're more than likely sagging a fair bit anyway.
Fronts old and new
And all done, just need to test drive it now
A bit of adjustment on the garage door and it should fit in Mr. Green
Ray Thumbs Up
Post #413780 4th Apr 2015 5:27pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Looking good Ray. What shocks are you using? My back end is up and down like a yo yo and I can't decide between oem oil or after market gas. 2002 110 td5
Post #413800 4th Apr 2015 7:00pm
mk1collector
To be honest I'm not sure Embarassed my garage put them on all round a year or so ago as the old ones were shot. I was going to put some bilstein on when I was fitting the springs because they get good reviews but with these being so new and in perfect working order I decided against changing.
Ray
Post #413807 4th Apr 2015 7:37pm
Pickles
Looks good to me.
Will you be getting a front end alignment?
Pickles.
Post #413852 4th Apr 2015 10:50pm
