![]() | Home > Puma (Tdci) > Oil Pump Recall for the Puma TDCi 2.2L EU5 - can anyone help |
| Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170
Does anyone know more about the oil pump recall for Ford TDCi 2.2L EU5 engines?
http://fordtransit.org/forum/viewtopic.php?f=5&t=149119 What about Land Rover? Has anyone asked for information on this issue? |
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
At work we have 5 x transits, 13 plate ones in at the same garage awaiting for this issue to be sorted.
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
As far as i know and only what ive been told , there is no recall , if it goes bang in warrentry then they fix it
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
As above..
We run a fleet including hundreds of them, no actual recall, just a TSB ... Will rectify if fails while within warranty period. We've had dozens go bang lol, only In transits though, Never had a Landrover or Citreon one fail ... |
"Never had a Landrover or Citreon one fail"
But http://www.defender2.net/forum/topic33872.html |
That's the full truth. |
| landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
does "rectify" imply a better version is bolted in ?
| Krissvdh Member Since: 18 Mar 2015 Location: Rutland Posts: 12
It is a recall. Owners should be receiving letters within 5 days. We are currently ordering oil pumps and related items by chassis number via our main dealer. Cheaper to change the pump than the possibility of X amount of engines, given the amount that have already failed. All 2.2s built between Sept 2011 and 31st December 2012 are on the recall - that's 15 months of engines.
Kris |
| nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720
Guys, what would your recommendation be for someone who owns a 2.2 built between those dates? As such an owner, I have had no recall notice but intend to contact the dealer in order to enquire. Is the replacement of different design? And if so would you recommend replacement regardless ? Cheaper than an engine out of warranty. Thanks
Sorry, Kris. I did not receive any. What are you talking about exactly? DEFENDERS? TRANSITS? A recall for TRANSITS will not help anyone here in this forum. But, a statement from Land Rover with respect to this recall from Ford would be appreciated. |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
THERE IS NO LAND ROVER RECALL, FULL STOP.
Let's just get that clear!! There may well be one for Ford's, but nothing for Land Rovers. An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
yet...
| Juhulia Member Since: 10 Jul 2013 Location: Dresden Posts: 17
What do you mean by this statement? The new recall 4S616 says Ford are providing a revised oil pump for all MY2012 engines. They acknowledge a failure risk. FORD TDCI 2.2 / LAND ROVER DEFENDER TDCI 2.2 engines and oil pumps are essentially identical. While oil pump failures are increasing, FORD are taking this issue more and more serious. I must therefore admit that FORD are providing good customer care. GUM97, are you happy that there's 'nothing for LAND ROVERS' ? Best, Julia |
easy option just ring land rover to find out
| All times are GMT |
