Home > Puma (Tdci) > Oil pump question |
mainly we find its the 2.2 having problems
don't think its so much the pump its self , more something to do with the chain drive from the crank down to pump normally knackers turbo as well Last edited by munch90 on 5th Jan 2015 7:18pm. Edited 1 time in total |
5th Jan 2015 7:12pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Thanks, so it's a Landrover problem too?
I was just wondering if there was ever a recall for this, or just a small few that were just unlucky! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
5th Jan 2015 7:16pm |
not a recall as such done , but fords seem to now about it , but if you get problems within what ever the warrentry is ,then they will do it , think if your out of warrenrty its your problem
I think it will be a problem with any 2.2 guessing there all the same inside not that common on the 2.4 , cant think of any of the top of my head what is your one your doing 2.2 or 2.4 ? |
5th Jan 2015 7:21pm |
2.2, customer has gone away to find a good second hand engine!
It turns out the van has never been serviced from new! No stamps in the book, oil was like water, 156000 miles! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
5th Jan 2015 7:39pm |
He done well then
some are only lasting 20-30,000m i think there has been 1 or 2 defender 2.2s on the forum with pump problems another reason to stick with the 2.4 |
5th Jan 2015 7:41pm |
On a happier note, I get to "squirrel" the old engine away under my bench, especially if he gets a "complete"replacement and not just a short block,
Spares for a few years! Many thanks for your info. Ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
5th Jan 2015 7:52pm |
vito115 Member Since: 29 Aug 2012 Location: kent Posts: 29 |
Someone i know had his Transit 2.2 euro5 recalled for a modified oil pump
5th Jan 2015 8:15pm |
GEllis Member Since: 21 Nov 2013 Location: Cornwall Posts: 58 |
I have a 12plate 2.2tdci 90 with 62k miles, just had a whole new engine and turbo all under warranty with three months warranty left due to oil pump failure.
5th Jan 2015 9:26pm |
Out of interest, anyone know if there are differences between 2.2 and 2.4 oil pump?
I was lead to believe that the blocks and internals were the same, Only bore size was different? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
5th Jan 2015 9:40pm |
I think only think the later 2.2 had a different oil pump drive chain tensioner or guide and it breaks , say not 100% on this
5th Jan 2015 10:45pm |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Is it the oil pump itself that fails? Is it sudden and catastrophic? OR Does it lose sufficiency (gradually or suddenly), pressure drops off and other engine components/bearings/top end/bottom end fail? OR Is it the chain drive from the crank to the pump that fails? OR Is it something else? Having bought a new 2.2 I'm interested in learning more - are there tell tale signs or is it sudden death? |
5th Jan 2015 10:58pm |
Think its the drive chain , should be able to find out more tomorrow
sudden death , normally complete engine and turbo needed |
5th Jan 2015 11:20pm |
Not sure what went, I will find out, but it was sudden. No warning, vehicle just stopped and the dash board warning lights lit up. Recovered to dealership new engine and turbo followed.
5th Jan 2015 11:27pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
The oil pump is different on the 2.2 from the 2.4 and so far has had three different part numbers which could indicate that problems have been found in production - a similar thing happened with he oil pump on the 2.7TDv6 in the D3 (went through five revisions - see the disco3 forum).
Tensioner and chain are the same between the 2.4 and 2.2 though |
6th Jan 2015 12:02am |
