Home > Maintenance & Modifications > Chekcer Plates
greigdef
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Chekcer Plates
Hi Everyone,
Im New to this whole Defender thing and have recently ordered one due in April. The only thing is now i have ordered it i keep looking at all the different things available and i keep getting told that i should have checker plates fitted to it. The only thing that concerns me is how do they actually fit to the car without damaging paintwork etc?
Greig
Post #405084 6th Mar 2015 6:01pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Don't do it, that's my suggestion, unless you're going to be walking over the wings and bonnet. I personally don't like checker plate, but I can see why western power and other utility companies fit it.
Post #405086 6th Mar 2015 6:10pm
Bows
Ta answer your question, you will need to drill holes where you'd like to fit it, then fix it with either pop rivets or some kind of countersunk fixing. A friend of mine had it fitted from new and it appears to have a thin layer of rubber or similar sandwiched between it and the wing tops.
Regards
Bows
Post #405091 6th Mar 2015 6:16pm
That. QRZ M8VPF
Post #405096 6th Mar 2015 6:21pm
K9F
I like the practicality of it. If you intend fitting a rack or doing your own work on the Landy it can be invaluable for bodily support when kneeling or resting on the wings toiling away. The bonnet is handy as my rack is a shorty as is SWMBO so walking on the bonnet is the easiest way of loading/unloading. The sills and sidesteps are now gone, replaced with R & T sliders. Mine is all fitted with gaskets and stainless fittings. It is a one way process that can be costly if you decide to revert back to standard.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #405097 6th Mar 2015 6:23pm
rustandoil
Wing tops yes, other places not for me.
And yes they are fixed with screws or rivits
Post #405104 6th Mar 2015 6:32pm
steve E
Wales
I have the wing top plate on mine in black so you don't really see it on a black car.
I've seen people use the wing top to look into their rucksack for something and it wasn't their car.
So I do like it within reason.
When I get the Heritage I will be leaving it as standard due to colour not looking right with plate on
It and it won't really be left anywhere open for abuse by Joe public.
My sills could do with it as I have scratches from getting in and out.
Horses for courses.
Post #405108 6th Mar 2015 6:38pm
IMHO Unless you are keeping the truck or need it, don't fit anything that can't be removed without trace
Post #405110 6th Mar 2015 6:40pm
K9F
Especially handy up the pub Christmas Day when the sun is shining and there's no room to swing a cat because everyone else had the same idea.
Rolling with laughter Rolling with laughter
Post #405113 6th Mar 2015 6:48pm
Flat wing tops will always be used to place things on, and not just by you as owner.
Get some fitted, not seen one with it making it look worse. It's a practical solution on a practical vehicle.
Post #405174 6th Mar 2015 8:50pm
Pickles
Definitely fit it.
We have wing tops, REALLY useful for placing stuff on etc, & we have the sills done, stops scuffing getting in & out & also the rear corners,...may as well get the lot!
Pickles.
Post #405177 6th Mar 2015 8:59pm
greigdef
Thanks for the opinions and views. I dont need them from a practical point of vieq i just liked them for the look. The only thing im not keen on is having holes in the car where they are riveted in. This is my first Defender so its all a bit New to me
Post #405239 7th Mar 2015 8:48am
DSC-off
If you don't need them, don't fit them. There's no going back once the panels are full of holes!
If you really want them, just fit the wing tops where they are useful but not too obvious.
Would a series 1s look better with it?
Each to their own, it's your choice.
Post #405480 7th Mar 2015 11:09pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
On my 110 puma I have silver CP on the wing tops and find it invaluable. I am considering putting a black sheet on the bonnet top as I have found it useful to climb on the wings to access the roof rack. In the absence of any bonnet protection I found myself balancing with my weight on the wing with one foot and the other on the bonnet hinge (seemed the strongest place)
The vehicle is black and I have roof rack mounted spots, so thought I would get less reflections from the lights.
Can anyone suggest a supplier of good quality black CP for the bonnet.
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #406896 12th Mar 2015 12:36pm
K9F
Mammoth make it all the usual suspects supply it, First Four, John Craddocks etc. Hunt round for a price, I would suggest if Paddocks do it their price may be the cheapest and it's a good place to start.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #406915 12th Mar 2015 2:06pm
