![]() | Home > Maintenance & Modifications > Under Ride Bar fitting |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 868 ![]() ![]() ![]() |
I had no problems when I fitted mine, you should have it done in half an hour
Tonyrec Member Since: 22 Feb 2014 Location: Lake District Posts: 137 ![]() ![]() |
Cheers, looking forward to doing it at the weekend.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2380 ![]() ![]() ![]() |
What's an under ride bar ?
If you mean the Landrover steering "guard" bar below you need a spacer on the o/s or n/s,can't remember which,lol, bout £5 from lr,some peeps pack it out with a load of washers,good idea to wax oil the inside,or use spray/axle grease,I painted (rustoleum) and stuck some clear vinyl film to mine to protect it from stone chips anorl.I get the impression they wont last long without.
![]() Click image to enlarge[/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
That's exactly what it is.
It's secured with 4 bolts (3 of which are already on the vehicle). The 4th has the spacer etc and utilises a hole that's already there. Our last 110 had this already on and whilst it doesn't offer the same strength as the large plates, I feel that its a bit more discrete and will do the job. It is something that can be specified on a new build from the factory for about £80. |
