Home > Puma (Tdci) > Puma EGR blanking plate FREE :-) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2288 |
can the exhaust manifold handle the extra hot gases when blanking the EGR? Puma 110" SW
1st Sep 2010 2:14pm |
? no extra T° w/o EGR. at full power (max T of escape gases) the EGR is closed Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Sep 2010 3:08pm |
Not sure how much is the max flow going into the EGR circuit, but again can the manifold take such volume? I´ve seen in this forum wrecked manifolds. Puma 110" SW
1st Sep 2010 3:40pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
The manifold should not be a problem, the egr would normally close well before max rpm.
Pete |
1st Sep 2010 8:00pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2620 |
Pete, how come BAS does not do EGR blanking kits anymore? |
13th Sep 2010 1:14pm |
13th Sep 2010 3:30pm |
oh right, didn't see that. But you don't give any details of the setup - is it just a blanking plate? does the MIL come on and stay on? |
13th Sep 2010 9:19pm |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
Very late back on this one, but just fitted my BAS plate to a 2009 110. You need to take the two studs out through the manifold, once you have removed the nuts, if you do not have a Torx socket, I found that an old 7/32" socket did the job perfectly, then take out the two 10mm bolts at the back of the engine that hold the EGR in place to give you enough movement to slide the old gasket out and put the plate in - I have gone for a 12 mm hole as this seems to be a popular choice. Hope this helps Guy |
16th Sep 2010 3:12pm |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
I have the same question, is this the fix? Allan |
17th Sep 2010 4:37pm |
Allan, Have a read through this thread and all will become clear... http://www.defender2.net/forum/topic3115.h...p;start=30 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Sep 2010 6:08pm |
In the thread everyone is using 18mm, I went straight for 12mm and have had no issues yet, been through about 6 drive cycles. The change has been quite dramatic, I have the BAS remap, the car is noticeably quieter, particularly at idle and there appears to be a little more power, but the delivery is much much smoother. Money well spent, thanks Pete! |
17th Sep 2010 8:21pm |
Thanks for that.
Allan |
17th Sep 2010 11:34pm |
BigFog welcome to the forum... I initially got my blanks from Robofarmer and was advised to 'start big and work my way down' each vehicle has it's own chracteristics and set ups (RAIs, remaps, air filters etc. etc.) I followed the instructions and have worked my way down over several months. I am now running on 10 mm and have had two recent incidents of code P1103 and a MIL light illuminating and this was after a considerable amount more than 6 driving cycles after fitting. I am considering going back up to 12mm and fully agree that it was money well spent. (As indeed was the scangauge that affords me the ability to read the code and reset my MIL light w ithout waiting a further 3 or so driving cycles). If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Sep 2010 8:37am |
Thanks for the welcome, Pete told me to start in the middle of the pack and after reading tbd other threads I went straight to 12mm. Is there an argument that the restricted pipe will be more prone to coking up, therefore reducing airflow, possibly resulting in the position you are in with warning lights after many miles without them? |
18th Sep 2010 12:28pm |
