![]() | Home > Puma (Tdci) > Puma EGR blanking plate FREE :-) |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2510
can the exhaust manifold handle the extra hot gases when blanking the EGR? Puma 110" SW
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
? no extra T° w/o EGR. at full power (max T of escape gases) the EGR is closed Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
Not sure how much is the max flow going into the EGR circuit, but again can the manifold take such volume? I´ve seen in this forum wrecked manifolds. Puma 110" SW
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
The manifold should not be a problem, the egr would normally close well before max rpm.
Pete |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Pete, how come BAS does not do EGR blanking kits anymore? |
oh right, didn't see that. But you don't give any details of the setup - is it just a blanking plate? does the MIL come on and stay on? |
| BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537
Very late back on this one, but just fitted my BAS plate to a 2009 110. You need to take the two studs out through the manifold, once you have removed the nuts, if you do not have a Torx socket, I found that an old 7/32" socket did the job perfectly, then take out the two 10mm bolts at the back of the engine that hold the EGR in place to give you enough movement to slide the old gasket out and put the plate in - I have gone for a 12 mm hole as this seems to be a popular choice. Hope this helps Guy |
| Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166
I have the same question, is this the fix? Allan |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Allan, Have a read through this thread and all will become clear... http://www.defender2.net/forum/topic3115.h...p;start=30 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
In the thread everyone is using 18mm, I went straight for 12mm and have had no issues yet, been through about 6 drive cycles. The change has been quite dramatic, I have the BAS remap, the car is noticeably quieter, particularly at idle and there appears to be a little more power, but the delivery is much much smoother. Money well spent, thanks Pete! |
Thanks for that.
Allan |
BigFog welcome to the forum... Treat every day as if it is your last....one day you will be right!! |
Thanks for the welcome, Pete told me to start in the middle of the pack and after reading tbd other threads I went straight to 12mm. Is there an argument that the restricted pipe will be more prone to coking up, therefore reducing airflow, possibly resulting in the position you are in with warning lights after many miles without them? |
