Home > Maintenance & Modifications > What are the best diff guards for a MY13 110?
Page 1 of 3 123>
Jim_Bean
I want to give my 110 a little more protection from all the knocks when green laning.
What are the best diff guards to go for?
I hear that the 'wrap around' guards are not brilliant but just wondered what other people's experience was. I also saw on another thread that the Qt guards, although very good, need some welding? I just wanted a bolt on solution if possible.
Qt? Wildbear? Terrafirma? Paddocks?
Post #403713 2nd Mar 2015 5:12pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
My old 90 survived a long time with just a standard 'rover' bolt-on guard on the front axle...
For the 110 I was just going to buy the two wraparound guards from Paddocks as they seem good value.
Not got around to it yet mind, so I'd be interested in what you decide!
Only thing with wraparound guards is that they do reduce the clearance slightly under the diff, although if you were to 'slide' over a rock on the guard that would be preferable to the rock hitting the diff no doubt! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #403737 2nd Mar 2015 6:28pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Went through the same dilemma a couple of months ago,
Ended up with a first four wraparound on the front- its OK but was an arse to fit. the top bracket that fits over the top pf the diff is a bit disappointingly wussy.
Have got a wildbear rear one to fit at the weekend, really wish I had gone for the front one as well- such a nicely made piece of kit. Have seen pictures of one fitted as well- fits like a glove.
Chris
Post #403768 2nd Mar 2015 7:18pm
QT wrap around, not cheap though.
Post #403782 2nd Mar 2015 7:35pm
QT Thumbs Up
Post #403791 2nd Mar 2015 7:42pm
x-isle
QT are now rebranded.
I tried to order some direct on the QT website but I had to ring them due to an "issue with their online payment".
So I phoned QT and they informed me that they have been rebranded as Wild Bear as they are now distributed via Bearmach. They are exactly the same apart from the logo.
Only the LHD versions require welding. The RHD ones bolt straight on.
The Paddock ones, are really bad quality, the galvanising it terrible and the welds were rusty when they turned up, so I sent them back and bought the Wild Bear.
I fitted front and back on Saturday. They are easy to fit, but do need some nudging to join the guard to the bracket. Also, with the P38 diff casing, it uses the 2 spare threaded holes on the diff casing. They will be filled with crap, so you'll probably need to run a tap through them to clean them out.
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #403799 2nd Mar 2015 7:53pm
Useful info above, I did notice they were remarkably similar but didn't think much more of it.
Post #403812 2nd Mar 2015 8:30pm
Jim_Bean
Perfect, thanks guys - top information as always Thumbs Up
Qt/Wildbear it is. Just need to find a good deal...
Post #403817 2nd Mar 2015 8:34pm
ozzie1989
Let me know if you find one Smile Now: 2010 2.4 TDCi 110 Utility Wagon
Post #403829 2nd Mar 2015 8:49pm
Jim_Bean
Hi x-isle
Did you know which Wildbear guards you went for?
I think I need a BA 7602 for the front and a BA 7610 for the rear.
BUT the description for the BA 7610 is for 'Defender 110/130' and the BA 7607 is for 'Defender 2007 on' Shocked
Somewhat confusing.
Post #403845 2nd Mar 2015 9:18pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I couldn't see from the photos but does the front diff guard offer protection to the output flange like the rear version does?
Post #403847 2nd Mar 2015 9:21pm
Harry.O
Double post - sorry.
Post #403848 2nd Mar 2015 9:21pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Corsetti 4x4 Thumbs Up
http://www.davidecorsetti.com/prodotti.php...d_cat3=126 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #403859 2nd Mar 2015 9:43pm
x-isle
After speaking with QT, they suggested ordering from Mailorder4x4 I had never ordered from them before, however, as QT themselves suggested them, I thought I'd give them a go.
These are the ones you need;
FRONT (Same as the QT model A1050A)
http://www.mailorder4x4.com/performance-pa...-1998.html
REAR (Same as the QT model A1080)
http://www.mailorder4x4.com/performance-pa...0-130.html
One thing that was wierd and I'm guessing is because it was dispatched direct from Bearmach (which incidentally is based in my home village in Wales) I had an email stating it was on backorder, then about an hour later it was dispatched and it came next day.
Very happy with Mailorder4x4! Thumbs Up
No it's slightly different as it bolts in place of the steering arm guard.
I haven't got a photo, but did find this on the internet. As you can see, it's a fair way up inside, so not likely to catch it.
[/quote] Craig Rogers
2007 Puma 110 XS
Post #403877 2nd Mar 2015 10:07pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Some nice stuff on the Corsetti website that I can't for the life of me figure out how to order!! Big Cry
G My confidence has been writing cheques that my abilities can't cash for years.
Post #403890 2nd Mar 2015 10:39pm
Page 1 of 3 123>
