Home > Puma (Tdci) > Rear Cross Member Corrosion
Page 2 of 2 <12
Likeomg
it's a chop off and weld back on ordeal... not ideal
Post #402391 26th Feb 2015 2:04pm
Green Machine
@ Paul55 The crossmember is a fabricated part of the chassis, it is not removable. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #402392 26th Feb 2015 2:05pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Caterham wrote:
sorry skip but that last photo as ingenious as it might be reminds me of that 80's TV series.......
the hammer house of horrors.
good luck and happy 'defendering'.
Gulp... Shocked
Post #402393 26th Feb 2015 2:05pm
x-isle
I last did mine 2 years ago, it was the first time it was done since new.
2 years on and it's still looking good with only a small amount of paint fade. The front bumper needs doing so I'll be giving it another going over at the same time.
If it's really bad, then you might need to sand it down rather than wire wool, but suspect it's just very minor being so new.
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #402394 26th Feb 2015 2:07pm
X4SKP
zone30 wrote:
Caterham wrote:
sorry skip but that last photo as ingenious as it might be reminds me of that 80's TV series.......the hammer house of horrors.
Gulp... Shocked
Caterham and zone30...are you having fun at my expense... Question
I just wanted it off the ground...safely... Exclamation
But to give you more to Rolling with laughter at...
 SKIP
Post #402403 26th Feb 2015 2:45pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Paul55 wrote:
Guys are the cross members easy to take off? mine needs doing as its just going on the ends, like to take it off if poss for a thorough job.
Thanks in advance Thumbs Up
If you're talking about the rear crossmember, in a word no it is part of the chassis and short of plasma cutting or angle grinding it off, it aint going anywhere.
I covered mine in Dinitrol 3125 from day one and after 4 years it's still like new, it doesn't actually look all that bad, certainly better than loads of corrosion....
Post #402413 26th Feb 2015 3:02pm
X4SKP
Hello Paul55
Cutting off completely is only for the brave, doable but you need kit and knowledge you say yours is
'just going on the ends'... if its rotten then it will need attention sooner or later,
LRM Magazine has just covered this Parts 1 and 2, cutting off and then welding on a replacement.
Selective patching up with is also possible if its not too far gone, but if your just talking about
respraying it then do that in situ.
If your welding on a new x member you can do most of the internal and external protection before
welding it on, keeping away from the weld lines then finish off these areas when in place. SKIP
Post #402424 26th Feb 2015 3:36pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I tidied mine up a couple of years ago as it had worn thin at the ends. I rubbed it down with a fine wet and dry paper then applied an etch primer followed with a couple of coats of black smooth right which gives a gloss finish so washes nicely (on the odd occasion I wash it) I use the car every day and looks as good as the day I did it. 2005 Td5 90 XS
Steve
Post #402444 26th Feb 2015 5:20pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Thanks to all for the replies much appreciated Thumbs Up Cogito ergo sum
Post #402459 26th Feb 2015 6:15pm
jimbob7
I used Rustoleum and a roller,thinned down with white spirit for a smooth finish. Pov.spec,ftw. 2006, 110,TD5.
Post #402532 26th Feb 2015 9:10pm
familymad
Do you have an angle grinder? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #402555 26th Feb 2015 9:49pm
Paul55
Hi familymad, i think i may have mislead a few people on my post, the cross member is rusting but only surface rust and not as bad as i thought, just a wire brush some fine paper and all should be well Thumbs Up the reason i asked about if the rear cross member was easy to take off was because i wanted to dinitrol thoroughly all over Smile again many thanks for all replies Cogito ergo sum
Post #402700 27th Feb 2015 12:17pm
Simon27
Scotland 2009 Defender 90 Puma 2.4 SW Tamar Blue
Wire wooled mine and just covered with a Plasticote rattle can 2 years ago - still keeps fine. A wee rub over with ACF50 once in a while and it's been fine.
Post #402935 27th Feb 2015 11:05pm
m33ufo
Wales
Mine is going a little milky.
So assuming not covered in the corrosion warranty but surely it's covered under the 3 year manufacturers warranty?
Post #615857 10th Apr 2017 7:54pm
MikeJ
United Kingdom 2013 Defender 130 Puma 2.2 HCPU Fuji White
I got mine done under the 3 year warranty.
They argued that it was part of the chassis and so not covered, but I persuaded them that it should be counted as bodywork because it's visible. It took a couple of calls to and fro-ing, but LR eventually paid for it to be repainted, and the body shop they used did a very nice job.
Mike
Post #617665 18th Apr 2017 1:01pm
Page 2 of 2 <12
