Home > Technical > anti roll bar question
dioliahary
Hi i have a HT 1990, 90.
My truck has no bracketry for ARB but i have sourced the right brackets etc. the rear looks like i would need to alter some bits as the exhaust and dixon bate angle which secures to the chassis rail look like they would be in the way.
So i am considering fitting an ARB to the front only, has anyone got any views on this, done it, advice etc ta Question
Post #401585 23rd Feb 2015 11:15pm
ickle
Not done it but massive understeer would result I would imagine - through the hedge forwards!
Post #401618 24th Feb 2015 8:19am
NickH
England 2003 Defender 90 Td5 PU Rimini Red
You can fit just the front one without any ill effects.
The rear one doesnt do a massive amount anyway as you can probably tell by its thickness (very thin).
Early Classic RRs (basically the same suspension) used to have aftermarket kits available, one kit just had a huge thick rear arb, no front one, and the other make had a huge thick front arb and no rear one.
Crash on Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #401698 24th Feb 2015 2:33pm
rustandoil
I fitted a front ARB to my 110DC it made quite a difference Very Happy
I then went on to fit a X-ENG rear ARB ..... Thumbs Up
Post #401725 24th Feb 2015 4:02pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I've running only front ARB, it corners incredibility well at speed - no serious under steer issues except on wet roundabouts.
Just aim for the exit after the exit you want, and you'll be good.
@eddie
What difference did fitting a rear bar make?
Post #401879 24th Feb 2015 10:59pm
rustandoil
@mrd1990
It stiffened the rear up quite a bit, mind you the X-Eng bar is very thick, but results in very flat cornering in my 110DC
There is another ARB thread somewhere with pictures of mine freshly installed...
Other thread here http://www.defender2.net/forum/topic12583.htm
Post #401968 25th Feb 2015 11:23am
dioliahary
Thanks, hope the crash and exit quips are tongue in cheek Neutral
If its safe to do so I think I will give it a go, so far so good Thumbs Up
Post #402219 25th Feb 2015 9:23pm
