![]() | Home > In Car Electronics > 'portable' spilt charging system |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Oops! Double post.
![]() Last edited by Laurie on 4th Feb 2015 2:23pm. Edited 1 time in total |
You'd need something to limit the current to a level that the lighter socket fuse can handle.
Otherwise you would have a 'spilt' charging system
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
What about putting a 12S socket close to where you will travel the said battery, you could fit one at the rear next to the tow hitch for future use and 'T' into the charging circuit and put a socket inside. That way you'll have all the advantages of only charging when the engine is running and you'll be future proofed for when you get older and feel you need a tin tent
If you want something that is transferable then a set of crocadile clips with a fuse and the right plug for the lighter socket but as Laurie has said be carefull of the amps involved
About 3 mtrs of thin (5 amp?) twin flex should lower the current suficiently.
Just monitor it's temperature when charging an 'empty' battery. ![]() |
Coil it up nicely on top of the crash pad under the windscreen and you can use it to keep the windscreen demisted
| JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 105
May be a little late posting but what you might need is a regulated DC-DC converter like this one...
http://www.es-store.co.uk/product_details....ow_menu=26 Its primary use would be to regulate the output voltage, but by doing so it can also limit its input current draw to something you could feasibly get from a cigarette lighter socket - just get one rated to less than ten amps or so. Won't be too bulky either. Hope that helps!!! |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
I have one I made..
Can take a photo if you wish, works really well |
| captain slow Member Since: 22 Jun 2011 Location: Herts Posts: 357
I was also searching for this sort of thing to power the fridge on the way to and during camping trips, so any tips and pictures would be great.
Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
In short.
Lesuire battery connected to a high current relay to control split charge. Light on the box up signal charging Voltage display (switched to avoid parasitic drain) Discharge protector to avoid battery being drained. (Black box in middle) Anderson on side (direct to battery) CTEK connector on battery for top up (Some shonkey wiring, could do with a proper multi fuse holder etc but works) |
| mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142
pretty sure CTEK do a battery charger for DC-DC applications.
edit: maybe this one http://www.ctek.com/gb/en/chargers/D250S%20DUAL |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
the only thing I would say about putting the electrics in the lid
are risk of fumes when charging from the battery ( even if its sealed battery as they normally still have a regulated valve ) 1, corrosive 2 explosion if they is a spark |
