Home > Maintenance & Modifications > Auto glass and windscreen fitting
Gleaney
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hi all. I have a chip in my windscreen that has been tried to be repaired by Autoglass but has been unsuccessful and needs a new screen fitting. Does anyone have any experience of Autoglass fitting windscreens into Defenders ?
Cheerrs Big Cry Damn planet is short of Kryptonite !
Post #398938 15th Feb 2015 9:04am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Surely they can't do much wrong. Is it just a plain screen, it could be cheaper to buy and fit yourself if your excess is £75 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #398940 15th Feb 2015 9:15am
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
A lot depends on the fitter, had one replaced in Bristol and it leaked like a sieve where he used the wrong sealant. Had it re-fitted by another Autoglass technician up here in Scotland who happened to be a LR enthusiast and absolutely perfect. 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #398942 15th Feb 2015 9:23am
Gleaney
It's a heated one. And the people last time didn't seal it which caused major water leaks and corrosion inside on the bulkhead and the bloody dash had to come out. So I'm paranoid about getting it sealed. Damn planet is short of Kryptonite !
Post #398943 15th Feb 2015 9:23am
Gleaney
Josh. Did they seal it and use a new rubber? Damn planet is short of Kryptonite !
Post #398946 15th Feb 2015 9:35am
theorangebandit
What's with all this sealant people are using. I've fitted hundreds of windscreens and none of them have leaked nor have I ever used sealant. Only ever some hand soap to ease it into place. For me I've seen companies like autoglass smash a few screens. On the plus side the subsequent attempts were coated to then due to their fault. Don't forget fitting screens on this manner is now obsolete so its a skill that's fading fast among the new age.
All their work is guaranteed and if you have trouble with it then simply call them and they'll fix it
Post #398951 15th Feb 2015 9:56am
x-isle
I had my heated screen changed last year by Autoglass, he did a good job and also inspected it for any corrosion.
Thing is, it's all down to the actual fitter. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #398956 15th Feb 2015 10:09am
Terryt
Someone else posted on here the other day about Auto glass,they had a great service and were very happy with them.
Terry
Post #398958 15th Feb 2015 10:19am
Try Dave at VGS (Landyglass)
Post #398960 15th Feb 2015 10:21am
Josh K
The first fitter did use a new seal but sealed it with the wrong type of sealant that over time went hard and cracked allowing water through. The second fitter also used a new seal but used a flexible sealant that would "flex" and not set hard and that has worked well 2007 (57) Defender 90 (Sold)
Post #398961 15th Feb 2015 10:22am
x-isle
Probably bound by Autoglass as I'm guessing it's insurance. Craig Rogers
2007 Puma 110 XS
Post #398962 15th Feb 2015 10:22am
Probably but you'd be surprised how cheap VGS are and you know it would be right (first time) !
Post #398966 15th Feb 2015 11:04am
K9F
Autoglass...
You have no worries whatsoever, also get the seal off and the area thoroughly cleaned. I had two replaced in short succession by Autoglass and it is an ideal time to get the crud cleaned out under the seal and get it sealed correctly.
My advice would be to be in attendance and read carefully the issue of dirt ingress in the thread below, especially my posts and Fekete's on pages 1 and 2....
http://www.defender2.net/forum/topic2126.html
Whilst VGS are very good if you don't live near them they're no use to you, nevertheless they do have a list of authorised fitters for their products who are also good at what they do. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #398973 15th Feb 2015 11:25am
Mo Murphy
Why would you put sealer on the windscreen ? The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #398991 15th Feb 2015 2:08pm
K9F
To prevent dirt and grime build up and the associated dampness and water creep that collects inside the cab. Read the link above. Cured mine and others water in the footwells.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #398993 15th Feb 2015 2:21pm
