![]() | Home > For Sale & Wanted > Sale of the century.... |
| McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686
I've just cleared out a mate's workshop of all his spares and surplus parts and its all up for grabs
So, here's how this is going to work... If you like the look of something, phone, text or PM me with an offer - I dont get offended, if it's not enough I'll tell you, but if it seems reasonable then we'll have a deal. Postage is possible on most items but collection/forum relay/meeting up is obviously preferable; all items are located in Basingstoke but could be moved to Camberley. Pictures are available and can be posted/emailed on request, I'm scared that I'd crash the server if I posted them all... That all seems straight forward enough, so here we go, in no particular order.... - Rover SD1 3.5 V8 race engine, formerly owned by Mike Wolfe, c/w tubular manifolds, smooth box LT85 and LT230 - [s]ARB RD56 24 spline locker, in full working order when removed[/s] - [s]ARB air compressor and loom, in full working order when removed[/s] - North offroad Extreme wing kit, c/w front panels, sides and arches (well used), chequer plate tops and inner arches - D44 competition 8274 bumper and steering gaurd, cranked to suit extreme wings, c/w 8274 guard/cage - [s]ARB winch bumper, used but good condition, c/w D44 ground anchor mount[/s] - [s]Southdown 8274 winch bumper, very good condition, slight bend in nearside wing (easily straightened)[/s] - 2 x King 2" air shocks, 16" travel, as new condition - 4 x King 2.5" air shocks, 12" travel, as new condition, still boxed - [s]Kenlowe fan wiring loom and relay, as new condition[/s] - Set of 4 genuine Icelandic spec Defender arches and rubber inners, new and unused - 2 x 300tdi radiators, good condition - Good used 300tdi intercooler - Good used Td5 intercooler - 2 x unknown oil coolers - [s]Allisport uprated Td5 intercooler, good condition[/s] - [s]Warn winch control (5 pin), new and unused[/s] - [s]4ft Hi Lift jack, new and unused[/s] - 2 x 4ft Farm Jack, used but in GWO - [s]Gwyn Lewis stump hook, as new[/s] - Clamp on diff gaurd - QT front diff guard, new and unused - Rear wrap around diff guard - Autobox selector - [s]Ashcroft Defender autobox console and auto box shifter, not perfect but in good order[/s] - Td5 auto flex plate, ideal for converting your Td5 to auto - Southdown Defender Tdi fuel tank guard, used but straight - Defender 300tdi fuel tank, converted to take Td5 fuel pump, ideal for Td5 trayback conversion! - Custom defender rear x member with 8274 winch tray - North offroad tray back kit, includes wings and rear stays, setup for coilovers/air shocks, c/w chequer plate panels - [s]2 x D44 ground anchors with removable spades, good condition[/s] - [s]D44 ground anchor mount for front bumper, very good condition[/s] - the worlds biggest ally fairlead, used but plenty of life left - 4 x OEM 3.54 R&Ps, all in excellent condition - 300tdi turbo and manifold, only removed to fit VVT - unique jerry can based fuel tank, complete with feed and return hoses and fuel pump - [s]1 pair D44 front shock turrets and relocation cones, very good condition[/s] - 1 pair D44 rear relocation cones - 1 pair Terrafirma 1" bump stop spacers, used but good condition - [s]Pair of Terrafirma TF019 defender rear springs, fitted but never used, still boxed[/s] - [s]Pair of Terrafirma TF130 Big Bore defender rear shocks, fitted but never used, still boxed[/s] - 300tdi air filter (outer), new and unused - Defender 90 pickup tonneau cover, designed to fit around a rear cage and stays, good condition - Defender wing plastic grills, 5 x top left, 5 x top right, 1 x RHS, all in good condition. - Series 3 brake servo c/w twin circuit master cylinder - Oil pressure guage and sender unit - 18 x Alloy wheels nuts - [s]2 pairs of early 110 Alloy door tops with double sliding windows, excellent condition[/s] - pair of lightweight door bottoms, absolutely mint frames, skins have seen some use, perfect for reskinning.... - lightweight bonnet, has seen some use but generally good condition - Pair of QT race seats c/w 3 point harnesses and padding, good condition - 4 x Compmotive alloys, 7 x 16, generally good condition - pair of Defender outer wing skins, good condition, offside notched for roll cage hoop - Td5 Defender ABS module c/w master cylinder and breathe.... Ross 0780 3262299 The Scotia Winch Challenge Last edited by McS on 6th Sep 2010 9:20pm. Edited 3 times in total |
provided its a 1995 defender fitted with a 300tdi engine, yes it will
Ross The Scotia Winch Challenge |
| AfterHouR Member Since: 05 Sep 2010 Location: UK Posts: 1 |
Pm'd you re: the Terrafirma's
Regards AfterHouR |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
Great, i'll mention it to my mate. get back to you ASAP. Cheers BM52 |
| landy Member Since: 29 Aug 2010 Location: cheshire Posts: 34
pm you regarding the allisport td5 intercooler and the 4ft hi lift jack
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
How much for the rear locker, and compressor.
Thanks Andy |
Sorry mate they're sold.
| walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2718
Nudge nudge
Oil cooler 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
| All times are GMT |
